Question about RCA RTD210 System
RCA RTD210 The disc in the DVD player will not eject. When I press open nothing happens and when I press close it just continues to say loading. How do I get the disk drive to open and retrieve my disc?
I had a similar problem some time ago. In a hurry, I placed a DVD in the tray; and didn't notice that the DVD was not fully inside the tray (inside the insert of the tray). So the DVD got stuck; the only way to remove it was to open the RT210 by removing the screws located at the back of the unit.
Posted on Sep 07, 2007
  • 4 Answers
You should never use a disc thats scratched inside yiour machine its most likely your dvd machine is having trouble reading your media the best way to solve this is to unplug your machine wait turn it back on keep pressing eject it should eject dont use that dvd disc again hope this solves your problem did for me ;
Posted on Jul 31, 2007
SOURCE:
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray DiscĀ® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Why can't we get the dvd to eject?
Possibility 1 -
The laser light inside the DVD player is most probably no longer aligned and cannot read the beginning of the disk. Therefore it keep on trying to find the first line but it can't.
Possibilty 2 -
Your husband entered a pirated copy and sometimes the first few tracks are unreadable due to the lower quality of DVD-R used and it jams the laser light inside the DVD player.
What needs to be done is to unplug the DVD from its source and gently pull open the DVD drawer in order to remove the stuck disc inside. Once that is done, power up the unit and press on the "eject" bottom so that the drawer can close itself.
Good luck.
Aug 16, 2012 | Samsung DVD-V4600 DVD Player/VCR
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
RCA RTD315 Theater System The DVD Player recently
My identical system has exactly the same problem as the one described by dipaola, above. When I insert a DVD, the DVD carriage pops back open after a few seconds. In fact, mine won't stay closed even without a DVD in it, as long as the system is set to play a DVD. I'd like an answer to the big Q - Is there anything I can do about this, or should I just find another DVD player to hook into the system?
Nov 05, 2010 | RCA RTD315 Theater System
Hi, the dvd on my recorder stayes ejected? It will close but then will eject straight away? What can I do? Cheers.
The fault is not from the disc, it is from the player.
The disc tray is actually malfunctioning. Which is as a result of a fault on the mechanism that is controlling the opening and closing of the disc tray.
Another fault might be that the button that controls the disc tray might be stuck.
test if it is the button.
  1. Unplug the player from the power source,
  2. plug it back,
  3. turn it on,
if it opens without you pressing the open button, then the fault is from the button.
check it for any irregularity.
  1. get the appropriate screwdriver,
  2. open the cover of the player,
  3. carefully force the front control panel open from the sides,
  4. then check for any damages,
  5. change the open button and it will be okay again.
test if it is the disc tray
press the open button, if it opens closes continuously.
then there is a problem with the mechanism that controls the open and close of the disc tray.
to fix this,
  1. Get the appropriate screwdriver,
  2. open the back cover of the player,
  3. look to the left side of the player and you will see a mechanism that controls the tray,
  4. change the mechanism with a new one.
after doing that, the player will be in good condition again.
take care
Jun 18, 2010 | LG RH1777 DVD Recorder
Sony SLV-D930 GI - The DVD Drawer will not open when I press eject. The display says ''OPEN'' but nothing happens
Please unplug Sony dvd-vhs combo from AC wall socket for couple of minutes, replug back in and turn it ON, now press eject button to eject disc tray.
Let me know if problem still exist.
Thanks.
Aug 29, 2009 | Sony Televison & Video
REGION 2 DVDS ON REGION 1 PLAYER
1) Turn on the player with no disc in the tray
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 29334
4) When it works a 1 will appear in the top left corner
5) Press 9 to make it regionless.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all regions of DVD Disc.
Enjoy
Jul 18, 2009 | Samsung DVD-1080P9 DVD Player
Dvd player wont work
Same exact problem as above three. Now what?
Wish I could hear how others resolved the issue - or did they? It's just over a year old.
Apr 05, 2008 | RCA DRC8320 DVD Recorder/VCR
DVD not working!
sound like the lazer drive unit is faulty.
Expensive to fix.
My suggestin is by a new one.
Dec 13, 2007 | RCA 20F610TD TruFlat TV/DVD
RCA RTD210 System Logo
789 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
