Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
Engine keeps flooding out
My Huskee snowblower with a 5 hp Tecumseh motor ran fine a few times this winter, then would only run on full choke. Now it seems to choke itself out after running for perhaps 5 seconds or so. It starts, then dies, etc. Possibly a dirty fuel filter? Ice in the gas line? Haven't used it that many hours. It sits in an unheated/unattached garage when not in use.
  • 49 Answers
Recommend completely draining the fuel system. Tank, lines, and carb. Make sure everything is clean and dry. Clean or replace fuel filter. Always try to store it with a full tank of fuel. It is common to get condensation when the weather goes from warm to cold and back.
Posted on Feb 05, 2009
Huskee snowblower help
so you only have idle speed ?
it must start hard
there is a governor but not normal to go out of adjustment
check carb linkage and springs
does your thottle lever move anything when you move it ( as far as throttle plate or any linkage?
Oct 14, 2013 | Tecumseh Snowblower Snow Blower Starter...
Craftsman snowblower Model 536885214 plug in electric start, started, ran few minutes, now turns over but wont start ?
My 8 horse has an adjustment screw on the carburetor Turn it out a little at a time till it keeps running Just don't over do it If you turn out too far you will flood it.
Dec 26, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Tecumseh 5 hp snowblower carburetor adjustment
Having to run the engine with choke on indicates that there is an air leak somewhere in the fuel delivery. Check the gas line for cracks, and if your model has a primer, the hose from the primer to the carb may be cracked.
Dec 21, 2012 | Garden
Our HMSK 80-110 electric start snowblower starts up right away, but the idling is very rough. It runs very smoothly when it is engaged in snow throwing.
The Tecumseh snow motors are notorious for idling rough. Especially the last few years of production. Most service techs just say "live with it" But there are a couple of things you can do to help.
It is not a carb adjustment issue. It's usually a fuel, clean carb issue.
First, use a premium grade fuel without ethanol and a fuel stabilizer. This will give you the best fuel mix.
Second, Remove the carburetor shield and clean the inside and outside of the carb with carb cleaner. Even though you can't see the carb usually, they do get varnish build up and cleaning it will help some.
Third, Put the recommended amount of fuel system cleaner in the gas. I use Sea Foam brand. Over a tank full or two you will notice a difference in how the engine idles.
Fourth, Use a high quality spark plug and use a new one every year. Make sure the gap is correct.
Good Luck! Feel free to as any other questions you may have. Don't forget to rate this answer!
Jan 14, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Backfire Tecumseh Generator
To maybe convert your Flamethrower back to a generator, Make sure the fuel line is a good quality thick rubber material (like OEM )since it passes through the engine,HEAT is a issue, if it has been modified to steel, or it's thin rubber, it will overheat the fuel on its way to the carb and cause backfires after the engine warms up , ( vaporizing gas and pressure bypassing the jets flooding the engine) I use 1/4 inch Goodyear sold at Autozone , one of very few name brand quality parts you can get there. The other possible cause is carbon deposits built up on the leading edge of the valve not allowing the valve to close all the way, just clean the valve, it is caused by too lean or rich carb setting or clogged jets, if it is a newer style carb with a pink main jet then debris in this area will always cause backfire, check and make sure the old tiny O-ring on this jet is not still in the bottom of the shaft, people forget to pull them out all the time or give up trying to pull them out, I use a paper clip and bend the end 1/8 of a inch @ 90 degrees to fish hook it out of there, CLEAN THE SHAFT with carb cleaner and a Q-tip.... A Tecumseh engine will always backfire if the carb or airflow is not perfect and sealed tight !!!!!! it looks simple to rebuild the carb but you must take your time and look close, clean it very well, make sure the jet is SEATED properly and all tiny holes are clean, use guitar string not torch head cleaners as they will enlarge the holes and make your carb run rich.
Jan 08, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh Snow King HS40 engine only runs on full choke, no power
i did and thanks - just picked up one that does the same thing and i plan to take your advise
Thank you Jerr
Jan 01, 2009 | Karcher 2500 PSI Pressure Washer
Snowblower won't start- electric or manual - has only been used a few times and always had difficulty starting it Model 8524
Sounds like its flooded. This same exact thing just happened to me.
Suggestion:
Let it sit with the the choke off. After a few hours, try starting it again, but don't mess with the choke (leave the choke set as if it was running hot). By your pulling of the recoil cord, you will be helping to clean out the flooded engine. Don not prime it during this excercise. (only pull the recoil 4 or 5 times).
Then let it sit again for a few hours.
After that waiting period, you should be able to start as normal, use the electroic start to get it going and lest it run, as normal.
You should then be all set.
Dec 22, 2008 | Ariens 34 In. Zoom Series Riding Mower
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
483 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
