my car shut off while I was driving, it started back up but now the check engine light is on. Could this maybe be the fuel pump? my car shut off while I was driving, it started back up but now the check engine light is on. Could this maybe be the fuel pump?
AnonymousApr 01, 2009
These cars are ****, I just had my fuel pump replaced today for the SECOND time, it went a year ago. I did NOT pay them for it, the crank shift sensor has been fixed twice so far. I'm going out this weekend to look at cars and get this lemon off of my hands. These cars are ****, I just had my fuel pump replaced today for the SECOND time, it went a year ago. I did NOT pay them for it, the crank shift sensor has been fixed twice so far. I'm going out this weekend to look at cars and get this lemon off of my hands.
You can't post conmments that contain an email address.
The tank does not need to be dropped. There is a access panel either under the cushion of the rear seat or in the trunk. I have to replace the pump on my 02
Its located in the IPDM box....remove the cover and you ll see a side with 4 relays close to the fuses and the other side 3line of relays,the relay in the middle is your fuel pump relay......hold the ipdm in position the fuses in the box upside....
yes you have to drop tank to replace fuel pump and filter as it is one unit pretty easy though.
crankshaft sensor is either under the harmonic balancer pully or bolted to block facing it you normally have to pull pully to change sensor but some you dont you will need a puller and a installer if you have to pull the pully
The fuel filter is located inside the fuel pump on a 2005 nissan altima. The fuel pump is under the back seat. You must remove the bottom cushion on the driver side. Before removing the fuel pump you must remove the negative battery cable and relieve fuel pressure
Take it back to where you had it serviced. They probably simply missed connecting the fuel level sensor. The engine light is probably from a missed emissions hose that goes to the gas tank.
