Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Odor is present within washing machine. It smells stale.
Is there a way to remove the aigitator and clean underneath it? Or is there something else that is causing the problem?
Run a load of whites and make it fairly strong with bleach. Bleach is essentially nothing more than chlorine (sodium hypochloride). It kills bacteria very efficiently and will kill the bacteria causing the smell in your washer. I do this at least once per month to keep the system cleaned out and I don't have a smell even if my wife forgets to take the load out for a long time. Beware, however, that if you have a septic system, the bleach may kill off the good bacteria that digest the nasty stuff in your septic tank and drain field. Thus, it's always a good idea to add septic system bacteria once a month. You simply flush it down the toilet. You don't need to worry about this if you are on a public sewer hookup. Hope this helps.
Posted on Jan 31, 2009
Why does my Whirlpool H2low washing machine have a foul odor?
Front Loading machines are notorious for odors. There are cleaners made to help remove the residue that builds up on the outside of the drum and causes odor. One thing that you can do to help cut down on odor is to leave the washer door open slightly when not in use. Closing the door prevents the drum from drying and allows the formation of the residue that causes the odors.
Sep 09, 2014 | Washing Machines
Tip
Should I leave my washer door open to reduce odor?
Washer manufacturers and cleaning experts in almost futile efforts to reduce odor advise to leave the door open to increase airflow. This does lessen odor but makes the odor-causing residue more difficult to remove. Also, the mold and bacteria residue is still present upon the next wash. If your washer smells with the door open or closed...it's time to clean it.
on Apr 12, 2014 | Washing Machines
Odor in washing machine
A lot of machines can suffer from this problem. It is usually down to a bacteria build up between the drum and the tub. The majority of appliances that suffer form this have been used mainly on 40 degree washes and with a biological detergent.
The best way to get rid of this smell is to place two tablespoons of washing soda or soda crystals in the detergent drawer and then run the appliance empty on the 90 degree wash. You may have to repeat this treatment before the smell goes but it will go eventually. Hope you've checked out & cleaned your filter.
You can give me a ‘very helpful’ rating for the help, can't you. Thanks.
Jul 12, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Mildew smell inside wash tub of my Whirlpool Cabrio
Apparently it's a common fault (among others) with this brand/model of washer; as Whirlpool has dedicated a page to it.
How to clean the interior of your washer to remove odors
Dec 19, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Stale odor within tub
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Dec 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Terrible odor from rubber seal around door. Don't know how to remove seal
Oct 14, 2009 | GE WSXH208A Front Load Washer
My Maytag stinks! Literally! It smells like mold or a cesspool. What could be causing this? Is there something i should be cleaning that I'm not that could be causing this odor?
This is normally a build up of dirt within drum....You could try boil wash on its own or buy a cleaning agent for that purpose/ also check sink is clean @ drain hose end. this can cause problems..Happy wash days....Good luck
Oct 04, 2009 | Washing Machines
Samsung washing machine smell
Keeping the lid shut is one of the worst things you can do for a washer. Obviously, the company you spoke to does not know what they are talking about. It is strongly recommended that you leave the lid OPEN when not in use in order to ventilate the wash tub and allow it to dry. There is always a small amount of residual water in the drain pump and lines, however, that will not evaporate. With the lid shut this residual water can sour and cause odors.
Consumers that do not normally use a HOT water cycle, do not use bleach, or run the washer infrequently can also experience odor problems with mildew and odor. It is recommended that you run at least one HOT cycle per week, or run a cycle with bleach when washing whites to keep bacteria and odors to a minimum. I hope this advice helps you. Let me know if you require further assistance.
Oct 25, 2008 | Washing Machines
Stale smell on crockery after wash
Most commonly, this relates to sulfides or other impurities in the water itself, but may also be caused by a buildup of food soil within the washer. Smell a clean glass of water. Does it smell stale also? If no, clean the screens and wash water sump/tank within the machine.
You can also clean the inside of the machine by using a commercial grade dish machine detergent and increasing water temp if possible.
If the water smells stale, consult a local water expert for guidance in resolving
Aug 19, 2008 | Dishwashers
Stale water smell
If the washing machine itself smells bad when you open the door, it could be that it's covered in a horrible grease and gunge inside all the hoses and the tub. This particularly affects older washing machines and is common with washing machines that have only really been used at 40° or where only liquid detergent has been used.
Not using enough soap detergent over a long period of time can cause a build up of grease and therefore bad smells.
Get rid of washing machine smells
You could try to clean the washing machine inside using Soda crystals which dissolve grease. I recommend putting half a packet inside the drum and washing on a boil wash (or follow instructions on the packet) Using this method every month or so, or using ordinary detergent if no soda crystals are available can help prevent smells from your washing machine. If your washing machine is badly affected by grease and slime, it may be very difficult to remove it.
Get rid of washing machine odours using vinegar
White distilled vinegar has an array of uses. For bad washing machine smells, try putting half a cup of white vinegar inside an empty machine and put it on a boil wash. Because the first bit of water goes into the sump hose and is sealed off, I recommend that you wait until the washing machine has been filling for about 30 seconds and then pour the vinegar into the soap drawer to let it wash down into the machine. I've had reports back from people that this does actually work.
Mar 07, 2008 | Hotpoint WMA40 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
205 people viewed this question
Dan Webster
Dan Webster
Sal De
