Laptop outputs graphics but not video to TV
Have a toshiba satellite, connected to TV with 9 pin cable, i can get the desktop to show and work. When I open a video player (WM or RealPlayer) they show and the video will play on laptop, but there is no video on TV - the program still shows. I can see visualizations if music is played, I can see the Realplayer "loading" icon when it starts up, but then just black. Any ideas where this problem lies?
  • 4 more comments
  • psedory Feb 01, 2009
    The laptop is set at the highest resolution which is 1024x768. might there be a setting on the TV to accept a lower resolution? I had the laptop connected to a projector a few months ago and it did display, but after playing for 30 minutes or so it went black and I couldn't get it back. So not sure that it would be solely this display setting.
  • psedory Feb 04, 2009
    Tried lower setting of 800x600 and no luck.
    Checked different cables and different TVs, the RCA video output on laptop does not seem to work at all (cables okay and TV s display from camera over RCA cables). USed the function f5 to set output to TV/monitor. So output only from the 9pin external monitor output, again there is all graphics displayed at any resolution, but no video from any programs.
    Video driver is latest for Nvidia geoforce 420.
    Just thought to check, I can go to youtube and play a video and it shows on the TV no problem.
  • JDTec
    JDTec May 11, 2010
    Can you try it on a different TV to isolate whether it is a TV or Laptop issue?
  • JDTec
    JDTec May 11, 2010
    Check your laptop's resolution. For the TV , you will need to set your laptop display to at least 1024x1024 or 1028x1024.
  • Anonymous Mar 22, 2014
    after about 90 sec. sound output stops graphic equalizer plays no sound until restart
  • 629 Answers
Try using the 640 by 480 resolution. If no go, update the video driver on the laptop. Try different cables to connect the system to the TV.
Posted on Feb 02, 2009
How to connect a toshiba satellite L675 to a tv using HDMI cable
If you TV has HDMI connections. All you need is a HDMI cable. Hook the HDMI cable into the laptop and into the TV. Turn the TV on and go to that HDMI connection on the TV. It will show everything on the laptop on the TV. Videos, Documents, and anything else.
Jan 18, 2013 | Toshiba Satellite L675-S7044 Notebook
Toshiba Satellite A350D - 003 laptop. Turned it on sounded like it booted right, but the screen is all scramble and looks like colored lines
The LCD screen may be bad, there is a video cable cord from the motherboard to the screen "may have come loose" But first hook a external monitor to the video output on the back of the laptop to see if clears up, if yes! then it is the laptop issue, if no! both LCD screens show the same problem, it is The Video Graphics Card that is part of the motherboard.
Jan 12, 2011 | Toshiba Satellite M50-0YU01N...
I am trying to hook up my laptop to my Toshiba 42'' TV. I am using a 15 pin VGA, TV is in PC, when I turn on computer and TV it will show Windows XP for a few seconds and the the computer and TV will go...
When you have them all connected, press the Fn key and while holding that down, press the F5 key, this will toggle the video output through all the choices. Give it a little bit of time, the vga graphics chip may need a few to send the signal to a larger display such as the tv.
Jan 22, 2010 | Toshiba Satellite M45-S331 Notebook
Change video output to s vedio connection
If the computer does not easily and automatically show the computer screen on the tv through the S-video output, make sure the tv is switched to S-Video and Hold down the Fn + F5 keys to toggle through the video output manually on the laptop. Just make sure that only one video source is connected at a time. Your laptop will not support two output sources at the same time. Below is the user manual in which it discusses the use of an external device on page 70.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2059997&rpn=PSPC0U&modelFilter=P305-S8832&selCategory=3&selFamily=1073768663
Oct 31, 2009 | Toshiba Satellite P305D-S8834 Notebook
I want to connect my Toshiba Satellite A305-S6863 Laptop to TV
You have to configure yout laptop to output through the s-video (which does not carry sound, so you need to either use the laptop speakers for sound, or the line output (headphone jack) to the TV).
I don't know if all toshibas are the same, but with mine, if I hold Fn (near the windows key) and press F5, it will change the output, do it a few times until you see a picture on the TV, some settings make this your extended desktop, meaning you can drag a window from one screen to another.
Apr 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Connect satellite pro l300 to samsung hdtv
Press Fn + F5 this changes the active display mode
Jan 19, 2009 | Toshiba Satellite Pro L300 Notebook
Computer TV output (RCA) - no colour
I had the same problem and nothing worked for me until I changed laptop settings to NTSC_M
So, briefly what I have: S-Video to S-Video cable, laptop (Thinkpad R51, Windows XP, with Intel(R) extreme graphics controler ) and TV set (Samsung, quite old one). The problem was that after connecting my laptop S-Video (4 pin) with S-Video (4 pin) of my TV, I had black and white (no colour) picture.
Solution is the folowing:
- connect your laptop and TV (both S-video 4 pins)
- mouse right click on your laptop desktop screen
- in the popup menu select: 'Graphics Properties'
- "Output to"
- select "TV"
- properties "NTSC_M"
keep in mind that if your are not connected to TV, Graphics Properties don't show TV as an option. So, that was very confusing for me, as I saw similar solution somewhere but was not able to find NTSC_M settings on my laptop
Good luck
Dec 15, 2008 | Computers & Internet
Problems connecting laptop to tv
Plug cable between TV and Laptop video output and press Fn+F5 to swap display to TV;
If it is not working, check if the TV setting on from BIOS.
If it still no luck you better change another cable to try.
good luck.
Nov 26, 2008 | Toshiba Satellite Pro M15-S405 Notebook
No display on tv
"please email me for further help if this dosn't help before you mark not helpful vicer@comcast.net"
first try updating your drivers at www.ati.com, I have to ask you to double check the connector your using to goto the tv, if your using a S-video cable check the port on the card your connecting to, if there are more then 4 pin holes in the connector you need a pigtail to connect to your tv, many video cards use a cable that is sold seperatly to connect to a tv, connector look like a s-video connector and a s-video cable will plug into it, but instead of 4 pin holes it has 7, 9, or 12 connectors depending on the card, and the type of output the cable has. most are 9 pin with composit, s-video, and componite connectors on them.
May 09, 2008 | VisionTek 7K RADEON 7000, (64 MB) Graphic...
How to connect my Sharp LC-26DA5U to my computer as a monitor
There are two possible problems: 1. You are connecting a 15-pin (on the laptop) to the 9-pin (on the TV) connection. This isn't the video-in connection for the TV. The TV has a DB-15 connection near its DVI input connector. You should be using a 15-pin to 15-pin cable. The DB-9 connector on the TV is a serial port for servicing the TV. 2. You aren't enabling the external video port for the laptop. Try hitting Fn+F5 on the laptop to cycle between the three display modes: laptop only, laptop + TV, TV only. Make sure to wait a few seconds after hitting Fn+F5 to let the displays sync up.
Feb 20, 2007 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
Computers & Internet Logo
381 people viewed this question
David Payne
David Payne
