HP Slimline s7527c motherboard needs replacing
The usb ports don't work and I had the computer checked. He said Motherboard bad. It has a pentium M mobo in it which seem to be costly and not that available. I realize if I change mobo I probably will need to change some other things. The young man suggested I put in a pci-usb port as a cheaper option. I would have to take out my modem card (which I am not using now) to do this. Any suggestions on specific Mobo combos, or what to do in this situation.
  • 64 Answers
Yes just what you had stated. remove the card and put in a usb card. it is cheap and easy fix.
Posted on Feb 02, 2009
Hp pavilion slimline s3300 usb ports not working
I've had 2 SlimLines and both of them were plagued with USB problems for no particular reason. The second one started having problems after 30 days of use.
Nov 11, 2011 | HP Hewlett Packard Pavilion Slimline...
What processor supports a am35306 motherboard
HP and Compaq Desktop PCs - Motherboard Specifications, RC410-M (AsteropeA)gtabseps.gif
gtabblt.gif Motherboard specifications table gtabblt.gif Motherboard layout and photos gtabblt.gif Clearing the BIOS settings gtabseps.gif Motherboard specifications table Part / Feature Specification / Support Motherboard description
  • Motherboard manufacturer's name: ECS RC410-M
  • HP/Compaq name: AsteropeA-GL8E
CPU/Processor
  • Socket: 775
  • Supports the following processors:
    • Pentium D 900 series Dual Core (Presler)
    • Pentium D 800 series Dual Core (Smithfield)
    • Pentium 4 500 (Prescott)
    • Pentium 4 600 (Prescott)
    • Celeron D (Prescott)
    • Celeron D (Cedar Mill)
Front-side bus (FSB)
  • 800/533 MHz
Chipset
  • Northbridge: ATI RC410
  • Southbridge: ATI IXP450
BIOS features
  • AMI BIOS
Form factor
  • Micro ATX size form factor, 9.6 in x 9.6 in
Memory
  • Single-channel memory architecture
  • 2 x 240-pin DIMM sockets support unbuffered non-ECC 400/533 MHZ DDR2 memory modules
  • Maximum HP/Compaq approved memory is 2 GB
Expansion slots
  • Three PCI
  • One PCI Express
Video graphics
  • Integrated
  • Supports PCI Express x16 graphics cards
Onboard audio or audio card
  • Built-in Azalia 8 channel audio
  • Realtek ALC883 8-channel High Definition Audio CODEC
Onboard LAN
  • Realtek RTL8100 10/100 Mbps Fast Ethernet controller
Back panel I/O
  • PS/2 keyboard (purple)
  • PS/2 mouse (green)
  • One SPDIF out port
  • One S-video out port
  • One VGA out port
  • One Parallel port
  • Four USB (2.0)
  • One IEEE 1394a
  • One RJ-45 networking port (LAN)
  • Audio ports:
    • line in (light blue)
    • line out (lime)
    • microphone (pink)
    • side speaker out (gray)
    • rear speaker out (black)
    • center/subwoofer (yellow orange)
Internal connectors
  • Two IDE connectors
  • One floppy drive connector
  • One ATX 24-pin power connector
  • One ATX 4-pin +12v power connector
  • Four Serial ATA connectors
  • One VGA connector
  • One IEEE 1394a connector
  • One CPU fan connector
  • One PC fan connector
  • One CD_IN connector
  • One front panel audio connector
  • One PC panel connector
  • Two USB connectors supporting 2.0 ports
NOTE: Motherboard specifications are subject to change without notice.
hope this helps
Sep 25, 2011 | HP Compaq Motherboard
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
I have a HP Pavilion Slimline s3700y that doesn't always boot. Power is getting to the computer; the light on the back lights up as well as the lights on the front. However, power doesn't seem to...
If you saying "doesn't always boot", most common would be motherboard...
If your motherboard still beeps, then probably some other components has the problem like RAM, GPU card etc., depends on your motherboard.
Hope that give an idea...
Jul 11, 2011 | HP Pavilion Slimline s3700y Desktop,...
Please show me the driver of intel motherboard and dual core system
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
don
Feb 28, 2011 | Intel DG41RQ Motherboard w Pentium Dual...
I have an HP Slimline s7613w pc, and about 3 weeks ago, all of my usb ports stopped working. As I was trying to diagnose this problem, I also found out that my wireless internet was not working as well. My...
Disconnect all your USB devices, reboot and then reconnect one at a time and see at what point your
problem occurs, but before you reconnect check your USB connector to ensure it hasn't been damaged
Feb 18, 2011 | ASUS Computers & Internet
My friend has an hp he bought - one or two years ago, everything works fine except the mouse and keyboard ports are all messed up from the cords being ripped out and put back in, is there any way to just...
Try the keyboard and mouse on anothe system. if it works fine the on board PS2 port is most likely bad. Buy a USB keyboard and mouse in plalace of the PS2 keybaord and mouse or change the motherbord. If the keyboard and mouse is bad replace with a good one.
Sep 28, 2010 | HP (D7580-60003) Motherboard
HP Pavilion Slimline s3122x powers up fan runs
Hi Im Rain.
I may have bad news for you. Its a very bad sign when your keyboard and monitor are not working at the same time. Sounds like the technician was right.
I also think its your motherboard. If you really just like the computer you can invest in another motherboard.
Nov 22, 2009 | Computers & Internet
I have a S3720Y hp slimline computer, the usb ports on the front of the computer have been damaged, where can I get replacements, hp parts doesn't show these as a replacement item?
Are all your usb ports damaged? If not a cheapy solution is to buy a multi usb port connector and plug it in undamaged usb...you will then have 3 usb 1 is usually high speed
Sep 06, 2009 | HP (5065-2501) Mini ATX Desktop Slimline...
Usb port is not working.
It was probably damaged if it is a new motherboard go to the person who sold you it and ask for a replacement and if you cant then you will need to either buy a new board or just live with the usb port which doesn't work.
Jun 09, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computers & Internet Logo
213 people viewed this question
David Payne
David Payne
