Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printed photo are very light - how can I get them to a true color
I have cleaned the head both basic and deep and calibrate it but its still light and no true color. I could only printer four photo and never geot back the real colour.
    Sergeant:
  • Kodak Expert
  • 285 Answers
Call kodak at 1.800.421.6699 for a new printhead. I hope this helps! please rate rate my solution. Thanks!
Posted on Feb 10, 2009
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer problem Koday Easyshare 5500
if you already tried a deep clean and there is no improvement on the printout then you need to buy a new printhead for your printer but if there is an improvement then do another deep clean until you get an acceptable print.
Nov 03, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Ip4000 printer prints but with horizontal lines
Cannon recommend a cleaning process called deep head cleaning
  1. Open the Printers folder.
    - For Windows XP select 'Start', 'Control Panel', 'Printers and Other Hardware', and 'Printers and Faxes'.
    - For Windows versions other than Windows XP select 'Start', 'Settings', and 'Printers'.
  2. Right-click the printer icon and select 'Properties'.
  3. Click the Maintenance tab, and then click the 'Deep Cleaning' icon.
  4. Select the ink tank color(s) for deep cleaning ('All Colors', 'Black', or 'Color').
  5. Confirm the message, and then click the 'Execute' button.
  6. The Power lamp will blink and print head deep cleaning will start. Deep cleaning completes when the Power lamp stops blinking and lights. (It will take about a minute for the Power lamp to stop blinking and light solid.)
  7. Print a Nozzle Check Pattern by holding down the <Resume> on the printer until the Power light flashes twice to determine if further cleaning is necessary. Up to three deep cleanings may be necessary to determine if the print head is working properly
Sep 11, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Will not print blue
clean head cardrige and calibrate color cardriges.
Jun 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Color isn't true
You'll need to calibrate your screen and your printer - calibration is required for every set of paper and ink you use. It's quite a science and an art. I suggest you google "colour space" "printer calibration" "gamut" etc and read up on it. Alternatively you could spend a few hundred quid on a printer calibration tool, either the Colormunki or the Spyder print studio.
It still won't match perfectly, as the way color is created on a screen differs hugely for to how it is produced on paper.
Start with a properly calibrated screen first though (my money is on the Spyder elite screen calibrator and spyder print calibrator)
I'm a pro photographer and I print my own photos - full system calibration is the only way. www.yourhandinmine.co.uk
Steve Causon
Apr 08, 2009 | Epson Stylus 1400 InkJet Photo Printer
Canon i9100 requires almost constant deep cleaning
The print head is probably clogged. I've had this scenario whenever the basement room temperature would dip below 20C.
Feb 10, 2009 | Canon i9100D (Bundle) Photo Printer
Colours are not true, grey is brown
You are getting leakage from one color cartridge to another. Do deep cleaning and run nozzle check. You may have been using non-Cannon inks. They can corrode the ink cartridge seats due to inferrior quality ink. You may need to replace the print head. Check out Cannon web site under this printer support. Print head is in the $50 neighborhood.
Feb 10, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Kodak 5300 print quality
The problem is in your printhead in which the cartridges sit on.
You will need to contact Kodak for a replacement print head. Once replaced this will correct your issue.
Thank you. - Go Columbus BlueJackets!!
Jun 28, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Owners manual for kodak 5300 printer
my inks are both full but it will not print out black and the color is faded
Oct 22, 2007 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
35 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
