Question about Sony 8mm Stantard Grade 120 Minute Camcorder Tape P-6120MPL USA 8mm Tape
Tape stuck in camcorder
Digital camcorder tape appears jammed, we cannot use the camcorder at all because we cannot access the tape pleae advise thank you kindly
  • BUSHMILLER Nov 08, 2007
    put the tape in an RCA machine, tape traveles a short way and jams up. I try to reverse and it remains stuck I can't remove it from trhe machine witrhout a lot of jiggling arounn. Next try the same normual proceduer and gfot the mix up. we continued on with some differnt machines some serious brain power all too no success, My next call is to FIXYA....Next using a G.E machine, serious brain power, and
Turn off
Take battery out
plug in to power
turn on
Tape shoudl pop out.
it worked for me!
Posted on Oct 02, 2009
Http://www.pechorin.com/m/2003/08/26/SONY_ORIGINAL_PARTS-203491-12.html
Posted on Dec 24, 2007
Tape jammed. Eject jammed.
Sometimes the tape is stuck on the head . Open the door and try to pry off the tape from the head with a thin instrument . Power up the unit and usually it spits out the cass. This worked for me many times.
Jan 30, 2013 | Sony Handycam CCD-TRV43 Camcorder
I have a Sony DCR-TRV250 Digital Handycam Camcorder. Currently a tape is stuck in it and the camcorder won't eject it. The tape unit comes out but won't open.
I got the tape to eject by removing the battery from the camcorder, putting it back on so that the tape would go back inside the camera. Then I had the tape eject again. Several times the tape would not be ejected but I repeated my steps until the camera released the tape.
Nov 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Tape jammed in jvc camcorder
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape.
Sep 08, 2009 | JVC GR-D250 Mini DV Digital Camcorder
I can't get my tape out- The door tries to open but it appears jammed...any help?
More likely the loading gears are damaged. When you open the outer door and the latch triggers the motor to release the tape compartment. When the gears are not in good condition, it will move up partially or none at all. The remedy is repairing loading gear mechanism. You will have to rely on your local camcorder repair technician for this job. -James. For further assistance by email, go to www.camerarepairjapan.com
Apr 03, 2009 | Canon GL2 Mini DV Digital Camcorder
Help! having similar problem with my camcorder?
Sounds like something is jammed in the tape carriage
Call canon and send it in for sevice.There is no tip or trick for carriage jamming issues
Jul 10, 2008 | Canon ZR500 Mini DV Digital Camcorder
Inserting tape into camcorder
bent guide pins, dried out grease, belts got old although you say new, some object stuck inside jamming gears.... the list goes on.
Mar 22, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Stuck tape in camcorder
I had a similar problem with an older panasonic camera. Mybe you have tried this, but opening the door and pushing up on the tape. Push in and use enough force but don't try to break it. Try pressing different spots. Sooner or later the motor might start moving it up. Just a though, it worked for me.
Mar 18, 2008 | Panasonic PV-GS300 Mini DV Digital...
DCR TRV320
That is the "LOAD" error code.
However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Oct 25, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Panasonic NVGS4 camcorder problem
Did you try with different tapes? light turr sound is always there in Rew/FF as the tape rotatets very fast. If the head motor stops while spinning, the error will be detected and the unit needs resetting. also if the head is sticky, tape gets stuck on head and unit will stop. Try to clean the head with head cleaner and check.
Feb 27, 2007 | Panasonic NV-GS40 Mini DV Digital...
Tape stuck!!
The tape is jammed. You can try to forcibly remove it your self but you may end up causing more damage to the tape carrier. Take it to a repair shop where they have the tools to remove it correctly.
Dec 14, 2006 | Canon MV850i Mini DV Digital Camcorder
Sony 8mm Stantard Grade 120 Minute Camcorder Tape P-6120MPL USA 8mm Tape Logo
1,424 people viewed this question
Top Sony Electronics - Others Experts
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
