Question about Kenmore 98702 Stacked Washer/Dryer
I tried to disconnect the buzzer on my dryer (Kenmore, Stacked, Model# 11088752794, and I didn't unplug it or turn off the power. I ended up touching two connections on the last electrode and it arced. Now I don't have power to any of the washer or dryer components.
  • 15,935 Answers
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!
Posted on Sep 13, 2010
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
Where is the lint trap on the Kenmore stacked washer dryer model 110.88752794
The lint screen is located on the back wall of the dryer. (Inside of the dryer.)
Here's a link to the owner's manual that may be helpful to download and print out: Kenmore 11088752794 Manual
Aug 26, 2015 | Kenmore Washing Machines
How to shut off dryer end of cycle beep. Can u run
If the model number is correct, the dryer End of Cycle signal cannot be adjusted or turned off. The informatrion is listed on page 11 of the Owner's Manual:
http://www.managemylife.com/mmh/owner_manuals/16695/WHIRLPOOL-Laundry-Centers-L0710382?brand_name_search=LTE5243D
The only way to turn the signal off, is to remove the operator console, locate the signal (buzzer) module and disconnect the wire(s). The buzzer is listed as item 32 under the "Washer/Dryer Control Panel" parts listing:
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-YLTE5243DQ2/1198/0152000/W0702346/00001?blt=06&prst=&shdMod=
CAUTION: If you choose this option, make sure you UNPLUG the washer/dryer before servicing anything inside. If you disconnect any wires, make sure you cover them with heat shrink or electrical tape to keep them from coming into contact with anything else.
The washer and dryer use a common power source, but the rest of the functions operate independently of each other. You can safely run both units at the same time.
If need further assistance, please let me know. I hope this helps you.
Aug 09, 2011 | Whirlpool LTE5243D Top Load Stacked...
How can I disconnect the alarm when the drying is finished?
  • Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
  • 2
    Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
  • 3
    Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
  • 4
    Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
  • Feb 17, 2011 | Miele Novotronic T230C Electric Dryer
    On the Kenmore 70 series, can the buzzer be disconnected? Our 5 month old gets startled each time that damn dryer buzzes (It seems like it last forever!)
    Hi, did you try turning the buzzer off with the knob on the right side of the operation panel (which is also used as the start button)? If you turn that knob to the left, it should turn off the buzzer.
    If it still buzzes, the switch behind that knob may be faulty. You can get at it by removing the panel at the rear of the dryer (6 screws) and then you can test it and adjust its internal contacts if need be.
    Hope that helps!
    Mar 03, 2010 | Kenmore 98702 Stacked Washer/Dryer
    Trying to disable the dryer's loud buzzer
    The wiring diagram is located in the slanted panel above the washer door
    Jul 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
    Dryer buzzer is SO LOUD - How can I adjust volume/turn off?
    Buzzer mounted to back of control panel.
    **UNPLUG POWER BEFORE REMOVING CONTROL PANEL OR TOUCHING -ANYTHING-!**
    Located on left side of control panel, bolted to back. Small rectangular device with two connections and no associated button or dial.
    Remove the panel and disconnect one of the leads. Fold the connector back against its wire, carefully and securely tape the connector with electrical tape so it cannot touch anything. Also tape the connector on the buzzer that you removed the wire from.
    Re-assemble the control panel.
    As with anything mechanical, hours of frustration trying to take something apart can be avoided by taking a few minutes at the beginning to look closely at how it is assembled.
    Mar 01, 2009 | Frigidaire GLET1031 Top Load Stacked...
    Disengage buzzer on Kenmore 400 dryer
    The buzzer is inside the control switch area. Its about the size of 4 stacked 50 cent coins. Kill the power to the drier and then open the control panel and locate the buzzer. Remove the two wires; using electrical tape, you can tape up each wire end and then secure it out of the way. :?) DRRXR
    Jan 17, 2009 | Kenmore 73952 Gas Dryer
    Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
    • the buzzer is located under the control panel.
    • you can unplug it.
    • unplug the dryer or turn the breaker off first
    • then take out the 2 screws on both sides of the control panel
    • bull it forward toward you and unhook it from the case
    • you should see the buzzer with two wires going to it
    • only need to disconnect one.
    •  just make sure you wrap the bare wire connector with electrical tape to keep it from touching metal.
    Jun 28, 2008 | Kenmore 60172 Electric Commercial Dryer
    Dryer buzzer
    Depending on the model some have a separate buzzer you can disconnect and tape off the leads to it. If it is an electronic timer you can muffle the sound by taking a piece of electrical tape and covering the whole on the small black speaker attached to the timer.
    Dec 18, 2007 | Kenmore 98702 Stacked Washer/Dryer
    Kenmore 98702 Stacked Washer/Dryer Logo
    74 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
