Question about Honda Quincy 17 - Gallon Air Compressor with 5.5 Hp - G15H17PC3B
IR EP100 compressor-getting change separator element alarm
Changed element still gives alarm. Lost a piece of surgical glove into the air intake weeks ago. Is this clogging something? I need a schematic of the air flow so I can better troubleshoot this. I am suspecting a solenoid and pressure switch located on the front inside wall of the unit that is plumbed to one side of the separator pressure by a 1/4" nylon hose. I dont understand the engineering behind this sensor since the opposite side of the separator seems to be plumbed to the output hose of the unit. Any ideas?
  • fredericksim May 11, 2010
    what alarm , is it air filter differential ,separator and or oil filter? the glove should have been schredded and deposited into the separator tank
  • 169 Answers
Ingersoll-Rand uses a differential pressure switch that should be hooked to the separator tank on the "wet" side of the filter and to the "dry" side of the filter, either to the sump lid or to the bottom side of the minimum pressure valve on top of the sump tank. if it is hooked up down stream of the minimum pressure valve it will not work correctly.
If it does not use this, it reads pressure between 2 transducers on the compressor to determine the pressure drop across the separator filter while the compressor is under load. ou need to determine what system you have first to figure out what the problem is. feel free to contact me through my website for more information
Posted on Dec 16, 2009
Element outlet temperature alarm in atlas copco compressor Model GA15 I changed the oil and oil seperator filter. I cleaned the oil and air cooler. The problem stil as it was.
OK. If cleaning the oil cooler and knowing the oil level is ok I recommend replacing the thermostat element. If you have a manual on your unit the part number will be in it. Recommend getting the kit which comes with spring, thermostat and o ring.
Dec 12, 2017 | Air Tools & Compressors
My ssrxpe60 ingersoll rand compressor is giving a high air pressure alarm and shuts down
I may be missing something here but typically a SSR is a rotary screw machine.XPE 60 is the model. It probably has a controller of some type for this person to know its shutting down on high air pressure alarm. So as the previous person kindly said don't give advise on something you know nothing about before you get some one hurt or killed!!!!
To answer the question. You may have a pressure transducer bad but most likely you have a minimum pressure check valve stuck in the closed position. When the compressor starts air pressure in the separator tank builds. At approximately 65 Psi the MPCV opens and allows air to the after cooler and out into the system. If the MPCV doesn't open the air pressure in the separator tank becomes to high. You then get the high pressure alarm and the unit shuts down.
Make sure the air pressure is zero, electrical disconnected and discharge line isolated from system. Once done you should be able to unscrew the aluminum cap on the check valve. Be extra careful due to spring tension. It should loosen as the cap is removed. If the parts inside are very corroded or you are unable to remove the cap you may have to replace the complete valve. If able to disassemble clean and purchase a rebuild kit for your MPCV if available.
Feb 21, 2015 | Ingersoll Rand Air Tools & Compressors
Reset change oil filter alarm after filter changed
I thought this is something that I.R. had to do but it's been a while.
Dec 18, 2013 | Ingersoll Rand Type 30 Electric Driven Two...
Changed battery in 2006 cadillac escslade and as soon as i hook up the new battery the alarm continues to go off. How do I reset the alarm
the operators guide, lost that? in the glove box.
then google for it. they are free.
the dealer gives them out for free, cutting law suits on safety big time. free and should be. for ever.
Oct 20, 2013 | 2003 Cadillac Escalade Ext
Spray is pulsing
this is usually caused by:
1. water in pressure tank of the compressor - clean the compressor holding tank
2. faulty valve in direct drive compressor (rare!)
3. dirty needle/gasket in the piece.
4. insufficient air flow
regarding 1:
stop the compressor,
open drain on separator and let all liquid out
allow pressure to drop to atmospheric
open drain valve on the tank and drain the content
on the compressor body find oil drain and drain oil
fill with new oil according to instruction on your compressor
close drain valve on the tank and separator
start compressor and check if problem is solved
re 2:
return valve is too difficult to change without specific model knowledge
re 3:
fill 1/3 (pint/500ml or less container)gun container with paint stripper and spray it directly to the sink or other container on full blast - WEAR SAFETY MASK, GOGGLES AND GLOVES! STRIPPER WILL BURN YOUR SKIN!
fill same level with water or solvent and run again, this operation should remove most of residual paints in nozzles and pipes.
check now nozzle for cleanliness and needle assembly, clean what necessary, use bit of vaseline when you will put it back together.
check for consistency of spray on piece of butcher paper with your usual paint. if problem solved - you are fine!
increase air flow... this actually should be done first.
for better instruction - please provide with model of the gun and paint used.
your comment and rating will be appreciated.
Oct 15, 2013 | Air Tools & Compressors
What is a surgical glove?
Surgical gloves designed to protect clinicians in operating room environments. The primary purpose of surgical gloves is to act as a protective barrier for surgeons and nurses to prevent possible transmission of diseases or pathogens during procedures while working with surgical instruments.
Feb 06, 2013 | Clothing Accessories
40 hp rotary screw IR compressor
Check if your compressor running in low pressure. If your discharge pressure drop @65psi the result is oil carry over.
Jul 01, 2009 | Ingersoll Rand Stationary Air Cooled...
Rudd exhuast and air intake lines
You need to make sureyou are at least 12" above ground with your termination if you live where you get accumulating snow levels. Next, your exhaust needs to be separated from your intake via a "goose neck"(straight pipe out of your house with 90 degree elbow pointed up then attach a 10" piece of pipe with a 90 degree elbow pointed out away from your house. The reason you want to keep them separated is that your intake will **** exhausted air into combustion chamber causing burner lift etc. due to no oxygen to properly burn. I usually put a 45 degree on intake so it is not so inviting to birds etc. Good Luck
Mar 10, 2008 | Heating & Cooling
Honda Quincy 17 - Gallon  Air Compressor with 5.5 Hp - G15H17PC3B Logo
315 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Tim Venetis
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
