Question about Whirlpool Duet GHW9150P Front Load Washer
Getting error cod f 70 on duet steam gas dryer
Dryer shuts off after 3 or 4 minutes.
  • 1 more comment
  • Anonymous Feb 14, 2009
    I have the maytag 5000 steam dryer and I am having the same problem, dryer will run for a few minutes then turn off and display F 70. We just bought 3 weeks ago.
  • jokenme Feb 14, 2009
    same problem but I have a 3 week old maytag 5000 steam dryer, ran for a few minutes then turns off and display reads F 70
  • Anonymous Feb 21, 2009
    Dryer ran 3 -4 minutes. Is officially 1 year old about 2 weeks ago. Getting error code of F 70 on Duet Gas Dryer.
mastatech
  • 478 Answers
SOURCE: whirlpool duet gas dryer ggw9200l need error codes
There is a mini manual located inside of the machine whith the codes and troubleshooting guide on some they are on left and some are under the top.
Posted on Mar 13, 2009
  • 5 Answers
SOURCE: clothes don't dry in my 4yr old whirlpool duet electronic dryer
If it is heating , check for a kinked or stopped up vent
Posted on Nov 18, 2009
  • 506 Answers
SOURCE: same problem but I have a 3 week old maytag 9000
From everything I have read on the F70 code (can't seem to find an exact explanation of what it is) It seems like people are getting replacement dryers due to a electrical problem within the dryer control circuitry. Since it is only 3 weeks old, get it replaced. Good luck
Posted on Feb 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: Slight Gas Smell From Inside Whirlpool Duet Steam Dryer.
Poor pilot - or malfunctioning gas valve.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
SOURCE: duet steam dryer soaked clothes and had alot of
Turn off the water or disconnect the water hose to your dryer.
Call your serviceman and tell him to order a new water solonoid for your dryer.
You can dry without the water hooked up to the dryer.
The steam cycles, however, will not have steam due to the absence of water.
Posted on Apr 01, 2011
WHIRLPOOL DUET GAS DRYER WGD87HEDW1
Unplug for 1 minute. Plug back in. Check status
Apr 17, 2016 | Whirlpool WGD87HEDW Duet WGD87HEDW 7.4 cu....
Dryer displays F 70 code. How do I get it to stop?
Unplug the dryer for 30 minutes. Then reconnect the power cord to the outlet. This will reset the code temporarily. Unfortunately, the code means that the central control unit (clock) isn't communicating with the rest of the components correctly. You probably will need a new clock or dryer (depending on the warranty status). If the unit is under warranty, contact Whirlpool or the store where you bought the dryer (if it is brand new).
I wish that I had better news for you.
Jun 05, 2013 | Whirlpool Duet Steam WED9500TW 7.2 Cu. Ft....
We have a gas dryer whipool duet . It dry the towel but it still litle damp and the flame it good , no vent hook up , and it run for 70 minute cycle ,. Any idea why that happen . Please hepl
If you are not venting the moisture from the towels away from the rear of the dryer that could be causing your problem. If the dryer is up against the wall try either moving it away from the wall or hooking a vent hose to the discharge and at least pulling the other end of the host around to the side of the dryer. The dryer pulls air into it self from the rear and bottom of the dryer so it could be pulling the moisture from the towels right back into the dryer making it take longer to dry. Hope that helps
Aug 29, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a whirlpool duet gas dryer and the burner turns on for about 2-3 minutes then shuts off for about a minute then cyle repeats itself. Any ideas?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101.
Oct 14, 2010 | Whirlpool GGW9200L Gas Dryer
Same problem but I have a 3 week old maytag 9000 steam dryer, ran for a few minutes then turns off and display reads F 70
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dec 20, 2009 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
My Kenmore series 70 dryer heats up but takes 3 times on 70 minutes to dry the clothes. After every 70 minute period when i check the clothes i open the dryer and it is like a steam room. It is getting...
Check your dryer venting for obstruction.  Take the vent hose off and run the machine,  If it works with the venting disconnected, It is between your wall and the outside of the house.  If it still has the same problem it is somewhere in the exhaust.  If the dryer can't circulate air, nothing will dry.
Dec 04, 2009 | Dishwashers
Duet gas dryer shuts off after 15 min
I cleaned out the vent that was clogged pretty good, put dryer back together (a solution I read in this blog), and now it is working fine. I was testing with bottom open.
Mar 21, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet GHW9150P Front Load Washer Logo
411 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
