Question about Gateway 7330GZ Notebook
Can not my gate way 6520GZ
Windows can start missing files
When pc 1comes on hold down f11 this should redo pc
Posted on Apr 28, 2009
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Feb 15, 2013 | HP Compaq Evo n610c Notebook
Following files missing or corrupt: \windows\system32\config\system
Well this means one of important files needed to start Windows is corrupted (it's a registry file).
I'd recommend repairing Windows installation. If you have Windows XP and also the Original Windows CD follow: this guide.
Dec 31, 2011 | Dell OptiPlex 740 (BPCW6TT) PC Desktop
Ok turn my gate way 6520gz on it does its bios screen normally then it goes to the screen where i would press f11 for system restoration like normal, then it just shuts down. battery fully charged, mother...
Yes it may be. When you cut it on will your Cap Lock light come on? If it does most likely it is your Hard Drive. You also if you have a system bootable disk place it in your CD-Rom and see if you system boots to it. If it does then your hard drive has a failure or a Virus has ate your boot sector.
Mar 27, 2011 | Gateway Computers & Internet
Runtime Error! Program: C:/Program Files/Sony/VAIO Gate/VAIO Gate.exe This application has requested the runtime to terminate it in an unusual way. Please contact the applications support team for...
Hi,If you want to fix the problem you can try to reinstall the application. If you just want to disable the message you can try this:
1. Go to Start Up \ Run command and type: msconfig then press Enter. 2. Go to Windows StartUp and search the item with this string: "C:/Program Files/Sony/VAIO Gate/VAIO Gate.exe" and remove the check. Then Apply and Close.
Mar 21, 2011 | Computers & Internet
I have a gateway 6520gz it wont power on i tried taking the battery out and draining the free power but the lights only turn on for just a second then nothing.
Hello Joalgd. hard to say this but looks like your laptop is done, it's a motherboard failure, it has a short somewhere and due to this short the laptop cannot power on.
Feb 10, 2011 | Gateway 6520GZ Notebook
Can create shortcut on Vaio Gate
hey just bought a sony and had the same prob, after looking its not to hard, just a quick edit to an .xml.
open the folder %AppData%\Sony Corporation\VAIO Gate and locate the file called VAIO Gate.xml.
Make a copy of this file so if you go wrong you can always restore the ori and start again.
Right click on it and click edit which should open the file in notepad.
Now copy the code i will paste after this, on a new line below into the doc after you find the first </Item>
n.b follow this word for word otherwise it wont work.
everything in between the *need to be replaced with what it tells you. when you have replaced the hints removed the star. When you finish there should be no stars in your code.
This is the code to pase in after the first </Item>
<Item Type="2" DisplayId="app.*first 4 letters of app*">
<DisplayString>*display name you will see in the gate app*</DisplayString>
<DisplayTip></DisplayTip>
<AppPath>*path to the .exe, e.g C:\Program Files (x86)\Adobe\Adobe Flash CS4\flash.exe no need for any quote marks*</AppPath>
<SupportTouch>0</SupportTouch>
<SupportRemocon>0</SupportRemocon>
<WorkDirectry></WorkDirectry>
<Option></Option>
</Item>
thats it save the file, close the gate and reopen it and if you will see the new icons. You can then drag to arrange where you want them in the line.
katg
Apr 25, 2010 | Sony VAIO CW2SGXB Notebook Core i3 i3330M...
Windows dont start
It means that some files needed for windows to restart are missing,probably a system file or boot files. Some windows xp users usually re-install and repair their windows xp system using their original windows xp install disk and selecting the "repair" ooption. But another practical solution is to note down the missing file, then,on another PC using the same system,search for that file and copy, though you will have to note the folder location of that missing file from another PC. Boot your PC (the one that doesn't boot) with a system diskand on the command prompt (DOS prompt) copy the missing file from yourcopy disk to the same location where the missing file should be situated.
If the practical suggestion wouldn't work, then you have to re-install your windows on top of the current installation using your windows cd to repair yourwindows sytem, if this still doesn't then you have to install a new windows systemlocated in a different location in your disk, this way you still go to your saved files and backup your files.
Apr 18, 2008 | Microsoft Windows XP Professional for PC
Missing product key
"Windows genuine advantage notification" is a mesage from bill gates and thats a mesage for piracy in operation system that mesage is in your computer program and was download from internet may be you try to download an update to one program and it comes with the downlad, the program check your operation system and the licens you put in and if do not macht start bothering you telling to you that your computer is not legaly registrate when the mesage "send dont send" apears press "dont send" what I do is instal the operation system again and say no to all update from windows(bill gates)..good luck and rate me
Jan 03, 2008 | Biostar 945GZ-SE Micro Socket 775...
Gateway 7330GZ Notebook Logo
37 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
