Question about Proscan 42LA30H 42 in. LCD Television
42 inch proscan lcd
When I use my dvd player and use the yellow video cord and plug it into component 1 jack I can watch the dvd but it is in black and white not color what am i doing wrong
If you use the connections for DVD you must use all of them.If you are using the standard yellow,white,and red connectors connect them to the connections listed as video and not the DVD titled connectors. But my advise is get an up converting DVD player and use a HDMI cable to get the best picture with out having to brake the bank buying a Blue Ray. I once connected a DVD player to my TV in the same fashion before finding out it only gives you a purplish black and white picture. Up converting DVD players can be bought around 30 dollars and up. A 6 ft HDMI cable will cost around 15 dollars. This way you will be getting the full effect and great picture your TV can produce.
Posted on Feb 03, 2009
I cant get a picture only sound not sure its in the right plug?
if your tv and dvd player are good yes might be you have a wrong connection. this is how a proper connection between your tv and dvd player.
  1. first step in connecting a dvd player to a tv unit is determined what kind of connection you want to make, this usually determined to the outputs and inputs available on the dvd player and tv unit.
  2. if you are using a plasma or a lcd tv usually the inputs are: composite inputs- lets you connect a component source like a dvd, vcr, and laser disc. component inputs - lets you connect another component source such as a dvd player. DVI-HDTV - lets you connect an HD receiver with a DVI output.
  3. for example if you select the composite input what you need is a RCA plug which usually a 3 color plug.this picture is an example of commercial rca plug which usually the color yellow use for video and the red and white color for audio.vinceisaac.jpg.
  4. this is how you will connect those wire into your dvd player and tv unit.look for the component output jack of your dvd player .this picture is a sample of component output jack the color may vary depending tovinceisaac_0.jpgkind of brand or dvd player do you have.
  5. now get your RCA plug then the yellow plug insert it to the Y or video out the red and white plug insert it to the left and right AUDIO out of your dvd player.
  6. now look for the composite inputs jack of your TV unit then get the other end of RCA plug. the yellow plug must be insert it to the V label for video the red and white plug into L/R label which mean for audio input.
  7. after you connect the 3 wires re check all the connections make sure the RCA plug is good and properly inserted to avoid loose contact which can affect the picture and sound quality.
  8. now turn on your dvd player and tv unit.
  9. make sure your tv unit is set to right input you want to use like for example you are using the video 1 input, you need to set to the remote controller into video 1 so that your dvd player must be recognized by your tv. enjoy watching i hope it will help you thanks for choosing fixya as your solution to fix you problem good luck.
May 26, 2011 | Apex Digital Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Have satelite as AV1, Wii as AV2 - hooked DVD player up as component 1 using RCA plugs but it is only black and white and very grainy.
Connect the yellow RCA jack, which is actually called composite video, not component, to the DVD. If it's component, it's the wrong jack and you'll need the additional 4 cables to satisfy a component connection for HDTV.
Dec 23, 2010 | LG 32LG30 32 in. LCD HDTV
I have a problem I am trying to connect my dvd player It shows black and white i have a proscan 32 inch what can I do to fix this ? please help.
Check to make sure the Video connector (YELLOW) is connected to a YELLOW plug on both the TV and the DVD. If it is plugged into a GREEN plug then it will produce the black and white picture and not a color picture.
Good Luck...
Feb 24, 2010 | Proscan PS32700 32" TV
I just purchased this tv. I had no trouble hooking up the satalite cable box but When I hooked up the dvd player the picture is only in black and white. How do I fix this?
Are you using component video (red/blue/green) rca jacks, or composite video input (yellow) rca jack? You need to match the color but watch out and do not get confused with the red and white RCA for audio.
Dec 17, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
How do i hook my dvd player to my tv? i have no manual to show me where to plug the wires into the back of my tv.i have a proscan 32LB30Q LCD
Hello pebbles12137,
This depends on what you want to do SD or HD
First if you just want to connect for SD only
Here are Three ways:
1) connect the coaxial cable to the DVD player F-connector (sliver screw connector) and the to the TV's Antenna in F-connector.
2) connect the yellow, red and white RCA connector end wires to the yellow, red, and white RCA Jacks of the TV Yellow (video in), Red (Right Audio in), White (Left Audio in) do the same for the other end into the DVD player (Best SD Method)
3) connect the svideo cable into the s-video socket of the TV and the other end to the s-video socket of the DVD player
For HD, Here are the connection methods:
1) Connect the HDMI cable to the HDMI in of the TV (HDMI1)and the other end of the HDMI cable into the DVD player. (best HD method)
2) connect the Component video cable (RGB) into the RGB sockets of the TV (should be marked as Component 1) and connect the other end to the DVD player (using this method you will have to connect the Red and White audio cables to the audio input jacks of the TV from the audio out of the DVD player)
These are the SD and HD methods.
I would suggest using the HDMI cables only, its the best choice and the simplest.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 21, 2009 | Proscan 32LB30QD 32 in. LCD TV
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Feb 03, 2009 | Proscan 32LA25Q 32 in. LCD TV
Black and White Video input
Check your plug that plug into computer, one of the legs has bend.
Jan 13, 2009 | Samsung T220HD LCD Monitor
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
DVD and PS2 in Black and White
HDTV:
DVD:
Jan 20, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Proscan 42LA30H 42 in. LCD Television Logo
227 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
