Question about Zenith B25A11Z 25" TV
No color on TV
My Zenith B25A11ZF HAs Lost all color!! My cables and connections are all fine... there's just no color.....but the kicker here is that the channel indicator in the corner is still in perfect color... i guess the problem is not with the picture tube but with the tuner somewhere... any ideas for a home fix...? thanks
  • john smith Aug 03, 2007
    I brought mine to a repair guy. He replaced an Ic chip on it and it works perfect now... only thing can tell you about it was it was rectangular and long...
    Champion:
  • 252 Answers
Change the crystal beside the IC the value is 3.579 .it is square metal
Posted on Oct 12, 2008
SOURCE:
I have 3 black stripes on my Zenith 42
Turn off the TV then unplug it. Disconnect the cable connection and clean the terminals. If the stripes still exist, you have a bad TCP (tape carrier package). It is responsible in transmitting color information to the display panel from the X-Drive (A-Bus) Board. This is not an easy repair. Service of an experienced or a qualified technician is recommended.
Nov 27, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Just trying to hook up a new DVD player to my 1998 Zenith TV?
Connect your video source [cable, satellite, etc] to your dvd and connect your dvd to your tv. Get back if you still have a problem.
Jun 19, 2009 | Zenith A25A23W 25" TV
Color lost on TV after hooking up Zenith DTT901 converter box
Try unplugging it if color regains its the box and not the TV!! if it dont regain then the flyback needs to be looked at. I am sure its the box and not the TV and yes had problems with zenth boxes Thank you
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | RCA F32665 32" TV
Sound
I do not have a Zenith B25A02Z TV. What I do have is a 1988 Zenith Color TV SE2517P. I called a local tv repairman and discussed the problem over the phone. He can take a look at it if we bring it in (service call to the home cost $100 just to show up). He said it was worth fixing since he thought it was only the sound. We have a great picture. He charges $20 to look at it but we have to leave it. He lives 20 minutes away one way. We think it is worth the trip if we can get it loaded into our minivan. We live in western NY where the weather can get pretty ugly many days. I will post the solution later when I know. FYI
Dec 30, 2008 | Zenith B25A02Z TV
RCA TV to DVD Player
Norm, I am assuming you are using component cables. Check to make sure you have the lines ran into the TV in ports e.g. Video1, HDMI1, HDMI3. Also check to make sure the system is not on MUTE or that the internal speakers on the TV are not turned off. If that fails and all was well before the new set of cables try another set.
Sep 04, 2008 | RCA 32F531T 32" TV
Red color gone on tv?
is the red gone on all inputs? do you have the tv hooked up, to a sat box, cable box via component video (Red, blue, green connections)? if so check the red cable on both ends.
Jan 29, 2008 | Zenith D52WLCD 52" Rear Projection...
Zenith LCD Flat Screen TV just shows vertical lines of color
Press menu button on the TV if the on screen display is also distorted or no pic the TV is definetely defective. You can try unpluuging from wall for about 15 minutes and see if reset helps if not problem is either main p.c.b , LCD panel , LVDS cable or Power supply board. and would require service. most likely problem would be bad connection at or defective LVDS cable that connects main p.c.b to Panel (cheapest fix) or defective main p.c.b. If it is the panel it would probably not be worth repairing and you may want to sell as is on ebay.
Jan 12, 2008 | Televison & Video
Color not working
If you are connected to cable TV with or without a cable box, I would first have the TV do an autoprogram again to verify that it is in the correct tuning mode for your cable system. If that doesn't dix it then there are many possibilities that can cause a loss of color.
Apr 12, 2007 | Zenith B27A11Z 27" TV
Black and White
There some thing that you had done to get black and white on your tv with the dvd ,check your connections.if the connections are properly connected then the tv could be having a problem in the video input, have a tech look at it.
Apr 03, 2007 | Zenith C13A05LG 13" TV
Zenith B25A11Z 25" TV Logo
106 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
