Question about Stairmaster 4600 Cl Cordless Freeclimber
STAIRMASTER 4600CL RIGHT PEDAL LOSES RESISTANCE AND SLIPS
WHERE CAN I FIND INSTRUCTIONS FOR REPLACEMENT OF RIGHT DRIVE SPROCKET ASSEMBLY?
  • 49 Answers
Http://support.nautilus.com/support/stairmaster.jsp?lid=StairMaster you can download and view all manuals here. If by drive sprocket you mean the hub that both step chains go over.....replace the entire hub. faster easier and less hassle. cost difference is about 40 dollars.
Posted on Sep 01, 2009
Check on line if not call the manufature.
Posted on Nov 02, 2012
Pedal slipping
Chances are the right hand clutch sprocket is failing. You can replace just the right hand side or the whole drive hub assembly. I usually find if the right hand side is gone, the left hand side is not too far behind. I will provide a link for the product I am referencing. Drive Hub for Stairmaster Steppers 4000PT 4400CL 4600CL 4400PT 4600PT...
Feb 26, 2014 | Stairmaster 4600 Cl Cordless Freeclimber
I have a 440pt and the left pedal is skipping down to the floor about every 5 seconds. If the issue is the hub assemble, do I have to change out everything or can I just replace the bearing, etc...?
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
Why does one Pedal Drop on my Stairmaster Stepper
Sep 05, 2013 | Stairmaster 4400PT FreeClimber
My Nautilus 4600cl right side slips.Would the drive hub be the probable cause?
Most commonly if one side slips and not the other, you are looking at the drive hub sprocket on the side that is slipping. Chances are, if you are experiencing slipping on one side and not the other, the one that is not slipping, is not far behind. It would be in your best interest to purchase the whole drive hub assembly.
Nov 23, 2012 | Stairmaster 4600CL Stepper Blue Console...
Stairmaster 4000pt pedal slips
Jul 07, 2012 | Stairmaster 4600PT Stepper
Stair master 4400cl Stepper making clunking sound user pedals when stepping
This can cause a clunking sound. For the replacement parts, please see the link below.
Apr 03, 2012 | Stairmaster 4400CL Stepper
I have a Stairmaster 4000PT. When using it, the left pedal will suddenly drop to the floor. Opened the case. The spring is intact. I used it with the case open and didn't notice anything different...
Sep 02, 2011 | Stairmaster Exercise & Fitness
The left peddle has a periodic quick drop as if it is slipping or something. There is a low popping sound whenever this happens. The drop is very slight and occurs about once a minute.
Mar 17, 2011 | Stairmaster 4400 PT Stair Stepper
My right pedal on my 4600 cl goes right to ground i belive the bushing is bad on the leveling arm the left side pedal is good and i nice and tight on the shaft where the right side was loose do u think the...
Dec 05, 2010 | Stairmaster 4600PT Stepper
Left pedal has no resistance right pedal is fine
Nov 11, 2010 | Stairmaster 4600PT Stepper
I have a stairmaster 4400cl and the right hand pedal intermittently slips and drops to the floor. it only does this a few times every 5 minutes or so. when i put weight back on the left pedal and start...
Oct 17, 2010 | Stairmaster 4400CL Stepper
Open Questions:
Stairmaster 4600 Cl Cordless Freeclimber Logo
1,093 people viewed this question
Top Stairmaster Exercise & Fitness Experts
fordexpert
Craig Butler
Craig Butler
zr800o1le
zr800o1le
Level 1 Expert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
