Question about RCA HD52W59 HDTV Projection Television
RCA HD52W59 Coverage issue Responce
The chassis number is RCA ITC22 and the model is HD52W59. I was looking thru some of the responces you've wrote others on this model and saw where you offered to email them a schamatic. The set will come on but the screen in miss shaped,sunk in at the top&bottom and the colors are off. It also has no coverage submenu in the main menu which points to fl231 fuse being blown.The TV does has a coverage issue because the fl231 fuse is blown. I'm a 14 year Industrial Process Control Tech with a year degree in Electrical & and a two year degree in Electronics Technology so I'm not a complete dummy, but i'm surely not a rocket scientist either.I write Allen Bradley PLC computer code and trouble shoot machines down to board level but have'nt worked on TV's in a long time but I feel if I had a drawing, well who knows. I under stand about your issues on every thing you've been busy on it seems like all my stuff dies at the same time to. Thanks a million and save my address and don;t hesitate to contact me if I can ever help you bra.
  • 905 Answers
That definately sounds like the convergence ic's have failed, you can try to find a simular schematic here ( itc 222 )
also here is some other things to try
1 in the service manual that disconnecting BW001 & BW002 on the Converagence Amplifier board may remove the load on the Convergence Power Supply , so disconnect turn on power then turn off and unplug from wall , then plug those back in and then power up , ( if you already replaced fuse and resoldered flyback)
2 resolder the flyback pins
3 check fl231 again , replace if needed
let me know if that does it or if we need to check power at the fuse or another part of the cicuit , but definately resolder ( one of rca's biggest problems)
Posted on Jan 31, 2009
Small signal board for RCA HD52W59
Thats caused by the small signal board located on the right side of the set ( Green board with the RCA plug inputs on it. Very common issue with that chassis. The board will have a barcode sticker with an as222 number. You can get replacement boards and any part needed for that model from
Jan 28, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Should I,change just the resistor that is burned?
Normally if a resistor has burned you will need to locate the cause or a replacement resistor will surely blow instantly in most cases? Is your model the HD52W59 RCA with the ITC222A chassis? If so let me know the resistor board location number such as RP256 etc.
Oct 15, 2011 | RCA HD52W59 HDTV Projection Television
Won't turn on-flashes 3 times.
Flyback and or CP150 are the most likely two components to cause that symptom. If you need more info let me know and also post the chassis number off the rear tag as that model used both ITC and ATC chassis numbers.
Mar 13, 2009 | RCA HD52W59 HDTV Projection Television
Hi, here you go, part number 233084 description 27 volt 1.3 watt zener diode, good luck, video-tek
Feb 03, 2009 | RCA R52WH73 Projection Television
Responce to clarify chassis number and problem with RCA HD52w59
when fl231 blows it is due to bad solder joints on the flyback and Vertical IC which places a strain on DL231 and CL230 the RCA bulletin states replacing the DL231, CL23o and FL231 then reflow the solder on the flyback and the vertical IC and that should repair the issue.
Jan 31, 2009 | RCA HD52W59 HDTV Projection Television
Circuit Board
try union electronics. thats where we get most rca parts for my shop.
Oct 11, 2008 | RCA HD52W59 HDTV Projection Television
e-mail me at and get me the chassis number see in the back of your tv under model number maybe chassis number
Apr 17, 2008 | RCA HD52W59 HDTV Projection Television
Convergence Problem
the 271860 is a convergence power supply IC. Exactly what was your problem, and could you please include the chassis number from your set, as rca has to be diagnosed by chassis number.
Mar 14, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
154 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
