Im having trouble my key board it is desconfigurated if i press the question mark it appreas exclamation what an i do_
  • 58 Answers
You can reinstall the keyboard drivers and try it again.
Otherwise you need to setup the program which you are using with correct keys.
Posted on Feb 01, 2009
NCr and nPr
Look your calculator in the face. Find two keys one marked nPr, the other nCr. There is third key nearby with the exclamation mark (n! or x!)
If the markings nPr, nCr,n! ARE ON THE KEYS, you do not need to press [2nd F] or [SHIFT] to access the functions.
If the markings are on the face plate of calculator you must press [2nd F] or [SHIFT] then the appropriate key.
To calculate 10P3 you enter 10, press [nPr] or [SHIFT] (nPr), enter 3 and press [= or EXE]
Mar 11, 2014 | Canon F604 Scientific Calculator
DSL yours did not put r4 but when I open it I see the name of r4 and with an exclamation mark
If you see any exclamation / question marks or red X's a new driver will need to be updated or installed right click select up date driver
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc If you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 i device arrows key scroll to nstalled. Hope this helps.
Jan 28, 2013 | Sigma 1.006596.V2.15 Luxembourg 1200/2200...
Im have a hard time geyying on the net
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure its enabledPci device arrows key scroll to nstalled. Hope this helps.
Jan 16, 2013 | Visual Land VNet VL760 Netbook
Can't connect to internet
im not sure these devices but if it has an operating system and cant get an internet connection
Jan 14, 2013 | Mach Speed Trio STEALTH-7CM4.0...
I can't connect to internet, Im using globe tattoo broadband.
Jan 14, 2013 | Dell OPTIPLEX GX110/200 PIII-866MHz 256MB...
IM UNABLE TO GET THE SOFTWARE FOR MY WEBCAM
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X
right click to reinstall drivers or update driver
W7
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question/exclamation mark ? ! or a red X a new driver will need to be installed
hope this helps
http://www.filebuzz.com/findsoftware/Universal_Software_For_All_Webcams/1.html
http://www.filebuzz.com/findsoftware/Webcam_Driver_For_All_Webcams/1.html
Jun 30, 2012 | Computers & Internet
How do you do a factory reset on a samsung galaxy europa smart phone? it has been locked and im unable to use my phone by the pattern locker
While the phone is turned off, simultaneously press the Volume key up and down, and then press End / Power. When an exclamation mark appears, press the Home key to reboot.
Feb 26, 2011 | Samsung Computers & Internet
Im having trouble putting a new operating system.cd rom wont pick up
Please provide the complete details.. make and model number, operting system!
Make sure you've tested more than one CD in the disc drive, it is possible for one CD to be bad or dirty and not be read properly
  1. Click Start
  2. Click Settings
  3. Click Control Panel
  4. Double-click System
  5. Click the Hardware tab and then the Device Manager button or just the Device Manager tab.
Within Device Manager verify that the CD-ROM has no exclamation marks or red Xs. If listed with a yellow exclamation mark or red X, remove the CD-ROM by highlighting the drive and pressing the delete key and reboot the computer to reinstall the CD-ROM drive
Jun 02, 2010 | IBM ThinkPad T41 2373 Notebook
Trying to scan photos and nothing is happening
In this case u need to update the drivers........
Insert the Software CD to the computer....
Right Click On My Computer.....
Click on Properties........
Go to Hardware......
Click on Device Manager.....
Now on that list u will find a option which will say Imaging Devices Under that u will see ur camera with an exclamation mark(You Can Sometimes see that Exclamation Mark Under Other Devices) if it doesnt have an exclamation mark but it says cannot find driver u can just uninstall and reinstall the software......
But if it has a Yellow Exclamation mark then right click on the Camera click on Update drivers......
Click On Browse my Computer for software..........
Select the CD Rom drive from my Computer........
And click nxt not it will say ur hardware is installed and ready to use....
If u donot see any Exclamation Marks right there just go ahead and Uninstall and Reinstall the Software that would work...........
Good Luck............
Apr 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
Computers & Internet Logo
281 people viewed this question
David Payne
David Payne
