Question about Philips Magnavox 51MP392H Rear Projection Television
Distorted Picture and High Pitch Squeal
I recently received a Phillips Magnavox PTV710 MDL # FP4640W102 47" the picture is distorted at the top. Looking from left to right across the top you will see a U shape or half circle that extends down from the top at the center 2"-3" This shape is blacked out except for the little white lines running thru it as if following the circle. This causes a warped effect in the picture. I adjusted the convergance the best I could but could not do the Green geometry as I don't have a template. This seemed to help some and also brought the colors in some. I think it also may need a coolant change. The green is foggy and Blue is dirty. It has also developed an intermittent High Pitch Squeal. Any Sugestions??? Thank You
  • Duane Baughman Feb 07, 2009
    Thanks for the reply. I've gone into the basic reb/blue convergance screen and I can move both in all directions. Here are a few pics of what my screen looks like. There is alot of backround light but take note of the color and the top center of the screen. The first pic highlights the bowed in effect.
  • Philips Master
  • 3,459 Answers
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and shouldDistorted Picture and High Pitch Squeal - 2c07611.pngd. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Feb 05, 2009
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
I have a 60" rear projection tv and the picture looks like its missing a color the picture isnt distorted or anything but the colors are bad what could be the cause and the fix
sounds like a Phillips or magnavox that has bad CRT coolant which needs replacement. If so you can get the Phillips CRT coolant repair kit from www.tvrepairworld.com it comes with instructions and the coolant for all three CRts,
Mar 01, 2013 | Televison & Video
Just recently the image became distorted at the top and bottom of the screen, like an arch going up from the bottom and down from the top?
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 11, 2009 | Philips Magnavox 51MP392H Rear Projection...
Top of picture is distorted
the problem of your tv was in the vertical section.if you can locate the vertical section, change the capacitor value 100/50volts
May 09, 2009 | Televison & Video
High Pitch squeal everytime t.v. is turned on. 20min warm-up.
sounds like the switchmode power supply is varrying in frequency ..needs to be checked by qualified tech,,,
Apr 16, 2009 | SNK Magnavox 19MF338B/27 19 in. LCD TV
CTR Television will not power up
What has happened is that the horizontal output transistor has shorted. The squeal you hear is the power supply running under a heavy load. The picture narrowing or being distorted indicate that the horizontal output was not operating clean. Something in the output section was not as it should be. Possible short in the output transformer/tripler unit or something loading down the secondary voltages generated by the horizontal output. You will need a tech to figure this out....If you are not a tech, then this ones a goner as far as fix it at home goes.....If you are a tech I might be able to talk you through the repair. Have someone remove the horizontal output transistor and I bet the squeal goes away.
Feb 10, 2008 | Televison & Video
Picture fades in and out
SYMPTOMS
Distorted Video, Partial horizontal size collapsed, pop sound, or high pitch squeal.
RESOLUTION
In very small amount of cases the capacitors listed below MIGHT BE reversed on the A Boards below.
This was found at the factory and corrected but a few boards might have this miss-mount.
Capacitors C450, C616, C632, C638, and C650.
A-1302-981-A
KV-32FS120, KV-36FS120
A-1057-457-A
KV-27FS320
A-1058-449-A
KV-32FS320, KV36FS320
Jan 02, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Phillips 27PT9007D/17 Manufacture Date May 2007
Have you changed any settings or added
any new components to the set like a
dvd player etc
Nov 20, 2007 | Philips Magnavox 27MS343S 27" TV
Picture distorted
Hello buddylaw,
Can you post a picture of the TV screen with the problem? It will help in the diagnoses. It looks like you may have a thermal sensitive component causing this issue. But I will have to seen a picture of the screen to properly diagnose this problem as to the possible section that may be causing this problem.
Thank you.
Shuttle83
Sep 10, 2007 | Sony KV-36XBR450 36" TV
High pitch ringing noise and picture distortion
Sounds like the capacitor that goes bad just before the hIgh Voltage transformer goues bad. If i were you I would call an authorized RCA repair Shope and see if this is going to cause more damage to your set in the future.
Aug 25, 2006 | RCA HD52W59 HDTV Projection Television
Philips Magnavox 51MP392H Rear Projection Television Logo
156 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
