5100 is a Carriage Home Position Error. try cleaning the plastic strip that runs the length of the carriage, it may be contaminated. Use alcohol and a swab.
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
hold the button with an orange blink for 10 to 15 sec.. then turn off your printer unplug the printer power cord. (wait for 5 minutes) plug the power cord and turn on your computer. hope it will help.
you need to reset your cannon by turning it on and off... for more detailed instructions follow this link to a faq on the issue from the cannon website
5100 is a carriage error, usually caused by grease on the clear encoder strip behind the carriage assembly. You can clean the strip with a damp Q-tip just damp with plain water.
Error 5100 is Carriage error.Possible problems in: - Carriage unit - Timing **** strip film - Logic board assembly - Carriage motor First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
6A00 is a purge assembly error, thats the cleaning unit on the right where the printhead parks. Look on the right with a flashlight and see if there's paper, or anything that doesn't belong. If the wipers are jammed into the pad assembly, you will need a new purge unit, best changed by a shop.
5100 says the carriage is not moving properly or there is ink or grease on the encoder. One time I found a camera card inside stopping it, but usually it's just grease on the encoder strip behind the carriage assembly.also if the purge assembly on the right is stuck in the up position you'll get that error.
