Question about Power Acoustik PTID-8960 Car Video Player
Have one wire for audio sub out, but two input ports to amp
Have a power acoustik PTID-8960 and attempting to install. Have 4 amps, 1 for the front speakers, 1 for the rear deck speakers, 1 for 2-12" subwoofers, and 1 for an additional 12" woofer from a mono amp. I understand how and where to hook up the front and rear speakers (including the 2-12" subwoofers) but am uncertain how to install (hook up) the mono amp for the single subwoofer. The amp we are using for the single subwoofer has two input ports (positive and negitive) but only one output wire from the head unit ("Audio-Sub-Out). How do we hook up?
  • lnl952 Jan 31, 2009
    Graindart,
    The head unit output is a single RCA plug. The amp input has two seperate RCA ports. On the output side of the amp is where we can hook up the speak pos/neg wires.
    President:
  • 1,990 Answers
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Posted on Jan 31, 2009
  • Travis Humphries
    Travis Humphries Jan 31, 2009
    Ok, That Makes more Sense! This is Set up just like a Subwoofer for your Home Unit. No Problem. Your Amp is a Dual Signal Amp and you are Connecting 1 Woofer, All you will need for this is 1 RCA Cable. Connect it to Either side on the Amp. Since you can hook up Multiple Speakers to this Amp and You are just Connecting 1, This is all that you Need. The Dual RCA Cables are Simply for Left and Right Speakers. Just Connect your 1 RCA Cable and you should be Just Fine. Make sure and Turn the Gain down ALL the Way before Starting to Fire this 3rd 12". The 12" is going to get the Full Power of the Amp and Could Blow the Voice Coil out if Started with the Gain up. Please Rate My Response! Thanks!
  • 38 Answers
Is the head unit output an RCA plug?  and the amplifier input speaker wire inputs?  If so, you'd need to find an RCA to speaker level wire adapter.  If I remember correctly Walmart usually carries one.
2 Suggested Answers
  • 323 Answers
SOURCE: Speakers are thumping and cracking when powered up...why?
you are better off setting your deck speakers amp to a high pass filter setting on the amp. Adjust gains to increase desired bass and clarity. Turn off loud button if you have one, that will distort your deck speakers.
Posted on Feb 13, 2009
What are the features?
POWER ACOUSTIK PTID-3265S CD/MP3/USB/DVD 3.2" TV STEREO SCREEN & 6.5" SPEAKERS
Mar 08, 2013 | Power Acoustik PTID-3265S
Installing a ptid-8960 power acoustik into my new 2011 mazda 3 what wires should connect or can i even install it without getting the wire harness adapter to make it like the same connections not quite...
You absolutely should use a wire harness for this installation. Not using one would require you to clip the wires to factory radio connector, making re-installation of the factory stereo nearly impossible. Even worse, you would have to wire the connector that came with your PTID-8960 deck to the clipped ends. This task would be nearly impossible, as the factory wiring is too short to extend out of the dashboard where you can work with it easily.
Save yourself the trouble.
I tried finding the exact item you will need, but it seems the Mazda 3 comes with stereo options that could affect which wire harness you'd require.
Here is a link to Crutchfield: http://www.crutchfield.com/p_120707904/Mazda-Receiver-Wire-Harness.html?tp=2977&tab=other_items
You can use their site to select your car and installed options, and they will return products compatible with your vehicle.
Jun 14, 2011 | Car Audio & Video
I have 2 15''s dual voice coil and i need to know how to wire them to my power acoustik bamf 4000 in a 1 ohm
most car-audio subs are rated at 4 ohms, as opposed to home audio's 6-8 ohms. If you have a pair of 4 ohm subs, wire all 4 positive terminals to the positive terminal on the amp and the sam with the negative sides. The key is to use the same length of wire on all connections.
Apr 28, 2009 | Power Acoustik BAMF4000/1D Car Amp
Power Acoustik PTID-4007 Okay, so I checked my radio fuse, it's fine. Checked for constant and acc 12v. and they are there. fuses on harness are good. I spliced my adapter harness onto the PTID-4007...
i have Power Acoustik PTID-4007 my problem is not turn on lcd not out audio but yes is take cd and out cd, the screen is move in three postion. help me please
thanks
Mar 08, 2009 | Power Acoustik PTID-4006T Car Video Player
My power acoustik 8960 touch screen does not respond
return it...it will start jamming when loading a disc and the fan will start to grind soon.  it is a bad unit..like all 3 I have HAD!!!!!
Feb 18, 2009 | Power Acoustik PTID-8960 Car Video Player
Feb 13, 2009 | Power Acoustik PTID-8960 Car Video Player
You can Actually get a Single to Double RCA Splitter for this. I think that Wal-Mart Used to Carry them. If not, Any Stereo Install shop has these and will sell them to you. You Might Try Best Buy also. Their Car Audio Install Guys may have one to sell to you.
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
WIRING
You need to order extra components in order to use the optional GPS function.. you can try checking circuit city or the Authorized Acoustik Suppliers for the products like the websites or you can check Ebay as someone might have the product
Nov 18, 2007 | Power Acoustik LT-980/2 Car Audio...
Power Acoustik PTID-8960 Car Video Player Logo
1,767 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
