Question about RCA DRC8300N DVD Recorder/VCR
It ate my disk, DVD won't open at all , says opening but doesn't
I put in a disk to play and nothing, tried to open it to retreive DVD out and not opened since, Press open on the remote, nothing lay the romote down walk away look back and the TV shows that it is opening but never does. I have had to unplug it in the past to let it reset but that does not work now. I would like to have the DVD out as it was a gift to me from my very special to me, Wife. I've not even seen the movie!!
  • 24 Answers
Flip it over and take the screws out, after you unplug it. Then look on the disk side and look for your disk, It might be jammed in their so be careful taking it out.
Posted on Jan 31, 2009
Doesn't load the disk
Someone needs to open it to SEE what is happening--if the unit holds more than one disc (model seems to indicate that) you likely have a mechanism problem with something jammed or even broken--mechanism could also be out of alignment which is a task for a pro.
Look and see what is happening is first thing needed here.
Apr 24, 2012 | Cyberhome CH-DVD 300 DVD Player
Wont play game disc
What disc are you putting in?
Mar 19, 2008 | Microsoft Xbox 360 Console
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
A dvd is stuck in the player and the eject button won't release the dvd. The dvd in the machine can be played (in other works the dvd player works) but if you press eject nothing happens.
Hi.I do not know if you can do it but no other way..Lets try it..
Please got a screwdriver and open the DVD case from the sides and back. It is simple, just some black screws. Then look in the unit and see and gently remove the disks by plastic holder open and sliding the disks out.
Then put the cover back on and put the screws back in. Should Work fine now.
I hope this helps you. Good luck.
Please let me know if you need more help.
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Aug 26, 2011 | LG RC897T DVD Recorder/VCR Combo
I have a bush dvd2039 and have put a dvd in and it won,t play and open and close won,t work either, have rebooted, unplugged and plugged back in and checked cables etc still nothing can you help please?
i take it your talking about a pc dvd burner if its not opening or closing i wouls say the cog/ruber band has broken you need to replace the driver (dvd burner)
Sep 21, 2010 | Bush DVD2038 DVD Player
My labtop just ate my dvd but i put another disc and it still works? how can i get the previous disc out?
The best thing to do would be to take the dvd drive out of the laptop completely. There usually is a screw on the bottom of the laptop holding in the drive.
Get the drive out and then with the end of a paper clip, put it in the hole in the front of the dvd drive so the door opens.
After you open up the door to the drive then make sure the dvd drive is upside down and shake it so any pieces from the disc that got ate up will come out onto the ground. If nothing comes out then you would need to take apart the drive by taking out the screws and then removing the pieces manually and then putting the screws back into the dvd drive.
Feb 02, 2010 | Toshiba Satellite A100-S8111TD Notebook
Will not play disk comes up no disk
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Apr 12, 2009 | Mintek MDP-1770 Portable DVD Player
About a thomson dth 8555x probleme
my thompson dvd decoder player doesn't play any disk...
it complain disc error
please help me out...
Feb 05, 2008 | Thomson DTH7500U DVD Player / HDD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
RCA DRC8300N DVD Recorder/VCR Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
