Question about Garden
Replacing a fuel line for a Poulan 2175 type 2 chainsaw
I am trying to replace the fuel line on a 1999 2175 type 2 Poulan chainsaw. The old lines have disentegrated and I need to find the line routing from the primer bulb. The info on the plate is
Family XPWES 0424CS:EM
DISP 36CC
SERIAL# 99106D201455-2
THANKS
  • 1 more comment
  • Anonymous Mar 09, 2009
    I recently replaced the fuel line to the carburetor. It goes through the gas tank wall and is a bear, but can be reached (just barely) through the gas tank filler opening. I also need to replace the line from the tank to the primer bulb and I do not see a way to do this procedure unless this line slips on a fitting outside the gas tank (?), since where it comes out inside the tank is visible but not reachable (unless the tank can be opened).
  • Anonymous Apr 11, 2009
    fuel line to primer
  • 10191 Apr 27, 2009
    Similarly ned to repalce fuel line that goes between carb and fuel filter pickup. I can see the routing, but the hose appears to be a very tight fit through the hole in top of fuel tank.
    My question is, is there any particular proceedures or tricks to getting a new line in through this small fuel tank opening?
    Thanks.
Take top cover off(3 screws). Take off the 2 nuts holding the carb on. Pull carb part way out to access the hoses. Remove the 3 old hoses after making a diagram of where they connect. Buy new hoses. Cut one end of the small hose on a bevel, pierce both sides 1/8 th inch from the end with a needle. Thread a thin wire through both holes. Thread both wire ends into the gas tank. Use a hemostat or long needle nose plyers to pull the wires and then hose down into the tank. Attach the weighted fuel filter. The other end of this smaller diameter fuel line goes on the upper nipple on the carb. Take the side cover off (4 screws) to access the primer bulb. Take 2 screws out to remove the bulb which has 2 nipples. The longer nipple connects to the larger diameter hose which goes to the fuel tank. The larger diameter tube has a coupler on the end which is inside the gas tank. It took me an hour to change all 3 hoses.
Bob
Posted on May 14, 2009
    Scholar:
  • 149 Answers
The fuel line from the tank filter goes to the carby and the other tank one goes to the "out" on the primer bulb. the other one on the bulb goes to the carby.
Now If the primer isnt marked there is a long and short nipple, and I cant rememer which is which...If you press the the prime rwith the hoses off you can find which one is sucking(in) and the one that blows (out).
The "in" on the caby (tank filter hose) is usualy the pipe that is in the aprox middle position, out (return, primer) is usualy ont outer position.....
the primer basicaly pulls air and fuel out of the carby and back in to the tank, not pushing it into the carby like most ppl think.
if it wont prime swap the hoses around on the carby and try....if that still dont work the caby diaphram might be US.
Posted on Feb 01, 2009
I also might add...the hose from the primer bulb to the tank is bigger than the hose from the primer bulb to the carb. No way can you put them on backwards. If this helps.
Posted on Apr 04, 2009
I had a hard time with the coupler on the end which is inside the gas tank. I ran a string in the opening and fished out throught the gas cap opening. Then I put through the coupler and tied a knot. That allow me to pull in position inside the tank. I threaded the string through the large tube an tried to push in the hole. After I finally got the tube in the hole I pulled the coupler into the tube inside the tank. I never could get the coupler back in the hole. Just got it to start.
Posted on Mar 01, 2010
How do i replace fuel lines?
Where do the fuel and primer lines go in Craftsman or Poulan Chainsaw
Hope this helps. Also try to avoid using gasoline with ethanol. This causes the lines to deteriate.
Apr 30, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Replace fuel line on poulan 1975
Hi Will...
I think this is what you need
Please take time to rate me
Bud
Mar 17, 2013 | Poulan 14" Chainsaw
How do ireplace gas filter in poulan 2055 chain saw?
the fuel line rots apart you need to replace the line pull the old hose out take a new hose cut down about a half inch cutting the line to about 1/3 slide a stiff wire down the hole and out the gas cap slide the hose over the wire and slide it back til the cut back end pops out put the filter on the end and pull it into place cut to size and install on the carb
Sep 01, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
Where can I find a diagram for the fuel system ? I let a someone who new less than I did try to replace old fuel lines. it will crank and run untill carb. runs out of fuel.
An exploded parts list for a 4218 type 2 chainsaw follows (May not be your saw):
Poulan.com The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. They are also beneficial with disassembly/reassembly. Fuel components and part numbers are listed but may be on different illustrations:
http://www.ordertree.com/modelinfo/PWE/PP4218-Gas-Saw-Type-2/75.PP4218-Gas-Saw-Type-2.1.59.1.html
The dash number of your serial number is the type.
A very good general diagram of a 2-cycle fuel system can be found here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using fixya.
Jan 08, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do i gey new fuel line through case and into tank?
Is there a metal fitting on the tank top that will unscrew? If so, pull the old line out with the fitting (remove the filter first). Be sure to use original type line, not plastic which is not flexible enough. Hope this helps!
Dec 18, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
May 07, 2010 | Poulan ES350 16" Chain Saw
Model 2175 poulan - pump up primer bulb and it colapses. When i put fuel in head it runs till gone..
Change out the primer bulb and the small gas lines going to carb and primer. One of these has a small crack to let air get by and this is how you get a flat primer bulb. Pick the kit up at lowes for $6-8.
Feb 03, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Fuel line routing help.
You should have one line (with filter) going to the carb inlet & one line going to the bulb then back to the tank.
Mar 13, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
4,329 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
