Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Bosch washing machine show E;04 plugged drain hose or pump
  • Anonymous Mar 16, 2014
    how to replace drain pump filter housing
  • 20 Answers
Remove cover to gain access to water pump, low rightside of front panel. Clean water pump. You should be good.
Posted on Feb 10, 2009
Bosch 24367
Drain hose or pump is blocked. Hose could be kinked.
Can you hear the pump running when it is trying to empty?
Nov 21, 2017 | Washing Machines
Bosch nexxt inspiration
You may have blockage-clean your drain trap-if this doesn't help you may have a plugged hose or something stuck in the pump-cheers Denny
Oct 15, 2013 | Washing Machines
Water is leaking from Bosch washing machine WFL2060UC. Checked the hose connections. Lots of water comes out of drain hose after one cycle and water is pooled in the pump (place where the cap is next to...
Bosch washing machine WFL2060UC This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 13, 2011 | Bosch Axxis WFL 2060 Front Load Washer
I have an Bosch washing machine, model WFMC6400UC 12391301. I get the drain blocked Fault notice on the control panel.I have opened the cover and observed the pump working, I have blown out the discharge...
Bosch washing machine, model WFMC6400UC 12391301 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water
Mar 31, 2011 | Bosch Nexxt300 WFMC220 Front Load Washer
Bosch nexxt 500. E04 message, checked drain area (round circle at bottom, checked ball valve, checked drain hoses, checked and cleaned container at the top right back of machine-where exterior discharge...
This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Feb 01, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Not draining properly (very slowly, causes error code). drain hose outside of washer is properly connected, no kinks, no obstructions. Error code "04" comes up repeatidly. After it finally drained we ran a...
The3 problem is more likely to be in the pump itself. No diagnostic except what you have jsut described. Open the outside covers and access the hose to and from the pump. More liokely on the inlet side and check the hose and the pump entry hole.
Please rate my help++++Thanks for using FIXYA
May 23, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Water is has not drained
Check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 19, 2009 | Bosch Washing Machines
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Error E;04
Located front down on right hand side. Remove cover gain access to water pump.
Jan 31, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch WFMC 3200 Front Load will not pump water out
the pump gears could be stripped or clogged with soap residue including the line from the pump to include the drain hose itself. I took the back of my machine off after cleaning the pump twice to find the reservoir full of a brown soap gunk/sludge. there is also a small rubber tube that runs from this reservoir back into the drum which was plugged shut with the same gunk. this thick soap residue can damage the pump motor or slow the drainage system to get the E 04 warning. I cleaned the gray drain hose out with the garden hose and was amazed at the sludge that game out. When the machine would run on the drain cycle we would also get a sewage smell that I thought was coming form the drain trap but turned out to be caused by the sludge in the pump. After cleaning the system and now using no more that a tablespoon of soap it works great & the cloths are clean.
Dec 18, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
351 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
