Question about iLO (2 GB) MP3 Player
Sync on to MP3
I have an Ilo MP3 player which is now starting to cause problems. When I connect to the USB port it rarely finds a connection. I've even tried different USB connectors. Main problem however is that when it does find a connection, it (Windows Media Player and Real Player) sometimes says that I dont have any music files on it when I do. When I try to sync files on it I get messages saying that "Windows Media Player encountered a problem while synchronizing the file to the device. For additional assistance, click Web Help." Please Help!!!!!!!
  • Kyndal Dec 08, 2007
    I have the exact same problem please help!!
  • 8,596 Answers
When you use an mp3 player on 2 different media players, it causes a format change when connecting to one or the other. Stick to one media player only.
Posted on Jul 05, 2008
ILO MP-556 MP3/WMA player
Revised iLo instructions for Windows Media Player 11:
Connect the iLo to the computer
In Windows Media Player 11, Run the mouse over the Sync tab
Click the little black arrow that appears underneath the Sync tab
Select More Options
Click the Devices Tab
Highlight the iLo
Click Properties
Uncheck box, "Create Folder Hierarchy on Device"
Download the firmware file at: https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip
then proceed with the rest of the directions
-Tha Mp3 Doctor
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable. 2. Open Windows Media Player. 3. Go to the Sync or Devices tab and delete all content from the player. 4. Go to the Tools menu and select Options. 5. Select the Devices tab, highlight the ILO or Siren player and click on Properties. 6. Uncheck the box "Create Folder Hierarchy on Device" ---- "Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connectedâ€
. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
Jan 10, 2009 | iLO MP3 Player
Tip
ILo Mp3 Player Help is Here
iLO Mp3 Player
"Flash Error"
Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
on Sep 13, 2008 | iLO (2 GB) MP3 Player
Problem with mp3 player
iLO Mp3 Player
"Flash Error"
Jan 06, 2009 | Jwin MP3 Player
Connecting my ilo mp3?
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 26, 2008 | iLO (2 GB) MP3 Player
My Ilo mp3 turns off when its pluged into the pc.
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Apr 22, 2008 | iLO (2 GB) MP3 Player
ILO 2GB MP3 Player Not Working!!!!
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Mar 12, 2008 | iLO (2 GB) MP3 Player
Ilo MP3 player locks up when plugged into MAC or PC
2)
Mar 05, 2008 | iLO (2 GB) MP3 Player
Sync to PC
I have had problems with that too, but i think i¨ve finally managed to overcome this. In setting>connectivity>USB connection menu choose Data Transfer/Service (I have Czech software, so excuse wrong names). Than Start LG Sync program, choose USB port and it should be working,
Although much more important problem for me is how to make built-in MP3 player play songs from external SD card without stopping after each song, not mentioning unavailability of other player functions.
Dec 26, 2007 | LG Shine KE970 Cellular Phone
Sync
Oct 14, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
