Question about Kitchen Ranges
Can't take apart the door on a Maytag Performa Stove
I'd like to know how to take apart the door on my Maytag Performa Stove. I'm trying to remove the glass panel on the front of the door.
  • 8,220 Answers
Set the door in the broil position and yank it off the hinges, set the door on a good work surface, carefully take the sides off first then the handle comes off then the glass comes out.
Posted on Jan 31, 2009
Maytag performa range oven top
If there are any screws around or in the burners, they have to be removed first. Once all the screws are removed, use a blade to loosed the burner. Then try turning again.
if you do get it open, lift just an inch or two to make sure you are not stretching any gas lines. They will break then you will need a new stove.
Oct 20, 2013 | Maytag PGR4410 Performa Gas Kitchen Range
My Maytag Performa glass top stove does not work. The oven doesn't heat up but the stove top works fine. I checked my fuse box downstairs and it is fine. I checked the stove to see if there were any...
Dear Gina,
It should be one of 3 things.
1) The element has burned out, or
2) The socket the element plugs into has failed, or
3) the wires hooked to the socket have toasted.
Someone must take the stove apart to see.
God bless your efforts.
Oct 26, 2017 | Maytag PER5710 Performa Electric Kitchen...
I was going to use the self cleaning on my maytag performa model number per57500qaw. It came on locked the oven door and never heated up so i cancelled the cleaning and the door would not open. we tried...
Hi, sorry but you have ended up on the washing machine forum!
May I suggest re-posting? I'm unsure what the forum heading is for ovens.
John C
P.S. We had a similar problem with an oven, sorted by removing and replacing power a few times BUT SLOWLY, maybe 10-15 seconds in-between!
Feb 27, 2011 | Maytag Performa PAV2200
We have a maytag performa electric stove, probabley about 6 years old, and last time we did the self clean on the oven we had a lot of stains that ran down between the inside and outside door panel. This,...
Can anyone please give me the serial number and product number to a 6 year old Maytag Performa glass top stove?? I just broke the ceramic top and need to replace it but don't have a serial number.
Thanks
Liliana.
Dec 12, 2010 | Maytag PER5710 Performa Electric Kitchen...
I have a maytag performa ceramic top stove andwhen I turn on the oven it will only heat up to 230 degrees
I have a Maytag Performa Ceramic stove top which I have "washed" the serial number, I broke the glass top and need to replace it, but I don't have the model/serial number. If anyone has one please give me the numbers. Thank you
lilkadoc@hotmail.com
Apr 27, 2010 | Maytag Kitchen Ranges
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
Where can i find a replace glass top for a maytag performa stove
Hi, get ma a model # and I can get you part # and location of a glass.
Vic
Jun 06, 2009 | Cooktops
I have a Maytage MER5775RAW electric stove and need to take the door apart
Try this website..it shows and exploded view and a parts list if you punch in your model number.. http://www.pcappliancerepair.com/model-display.php
Hope that helps...
Aug 22, 2008 | Maytag MER5775Q Electric Kitchen Range
How to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Jun 18, 2007 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
376 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
