Question about Garmin Nuvi 660 GPS Receiver
Screen has gone to bright to see. no contrast
Screen has gone to bright to see, and am unable to get contrast back
  • 214 Answers
Push the reset button. On the back lift up the GPS antenna and you will see the reset button. This should take care of your problem. If this helps you plz rate this. Thank you kindly.
Posted on Jan 31, 2009
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
How do I adjust the color, contrast and sharpness of my Dv2000 HP Pavilion?
You can use the "Fn" + F7 and F8 key from the key to increase the Colour and Brightness of the Screen
May 02, 2010 | HP Pavilion dv2715nr Notebook
Cannon NP 6551 (Danka A50) Touch Screen Lost Brightness
SOMEONE TURNED THE CONTRAST BUTTON ON YOUR DISPLAY, YOU JUST NEED TO READJUST BY PRESSING AND TURNING TO DESIRED CONTRAST
Apr 03, 2009 | Canon NP 6551 Black and White Copier
Dark screen
If you are unable to change the contrast with the 'fn' key and the brightness controls, usually represented in the top row of keys as a sun icons, one brightens, one dims. You may have a bad brightness/contrast inverter in your display. It's a small circuit board in the display that controls the brightness. They do fail. You can find them for most models but depending on your technical ability, they can be a little tricky to change.
Jul 26, 2008 | Compaq Presario V4000 Notebook
Screen on lap top has gone very dark and dont no how to get it back to normal
there are 3 possibilities I can think of
  1. The brightness or contrast has been turned down (check your manual)
  2. The power save settings are telling monitor to be at low brightness to save power (check manual)
  3. the back light has failed
Post back exact model notebook and I may be able to assist with more specific advice
Jul 08, 2008 | Toshiba Computers & Internet
Samsung 220wm monitor brightness and contrast adjustment
umm... you are NOT supposed to use mouse !!
These are on-screen displays and you can use the other buttons (up down and select) to navigate through and then to change the values !
Dec 27, 2007 | Computers & Internet
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
Garmin Nuvi 660 GPS Receiver Logo
109 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
