Question about Amana Ovens
Smoking Oven I have an Amana Gas stove - 11 years old - ARG7301WW Serial #9704178428. Recently whenever I cook something at 400 degrees or higher, smoke pours out of the stove from inbetween the liner. Even when I remove the food from the stove and shut it off, smoke continues to pour out for at least 15 minutes. Is it still safe to use, is it repairable, or do I have to buy a new stove? I saw that other models were recalled for a similar problem - is this model under recall as well?
    President:
  • Amana Master
  • 2,651 Answers
Soundsas if you have a dirty stove, Id reccommend running through en extended cleaning cycle, it will SMOKE, that s geting rid of any food/grease trapped inside the flue and cabinet of unit
Posted on Jan 31, 2009
Amana gas oven (model#: ARG7301ww) does not heat. I do not hear the gas turn on or the ignitor go when I turn on the oven. The burners on the range work as usual.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 07, 2011 | Ovens
I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
Jun 11, 2009 | Ovens
Oven cooks at 400 plus degrees when set at 350 degrees
If your problem is temperature do this;
Press "options" Then press "6". Then press "3" to increase or "6" to decrease temp.
Then press "start" to end the calibration.
If you recently used self-cleaning you could have a thermal overload fuse problem.
Feb 23, 2009 | Whirlpool SB160PEE Gas Single Oven
Gas oven that cooks unevenly
clean your orifaces.
Also make sure that it's the correct stove for your gas type. If you're using a NG stove on Propane, you're wrong. It's making a lot of soot, and could potentially blow up your house. Stop using it until you're sure.
Dec 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Oven smoking
I am pretty sure this is just the steam escaping. Smeg ovens seal so evenly that the steam stays in the oven.
Nov 12, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
367 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
