Question about Dishwashers
Whirlpool Model #DU890SWKQ0, Type 280-0, Serial #FM354339 - Closing detergent compartment will not open during cycle. Remains locked with detergent inside. Can this be fixed easily?
I have a whirlpool dishwasher 280-0 that will not drain. What can I do?
Posted on Oct 24, 2010
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
ADP 4730
The problem is with either the spring or the solenoid that operates the detergent compartment door. It should be released at the right time by the controller during wash cycle. You have to check the spring and see if it stuck. But if solenoid is faulty then whole detergent dispenser has to be replaced. You could switch to detergent tablet which you drop in the cutlery basket and it works fine. A brand like Finish works well and keeps dishwasher clean.
Alternatively you can purchase a replace detergent dispenser from
http://www.buyspares.co.uk/whirlpool/adp4730-851150429849/dispenser/product.pl?pid=18330&path=463858:496324,47872:463870&refine=dispenser&model_ref=641830
Also watch the video on how to replace.
Apr 23, 2014 | Whirlpool Dishwashers
My detergent compartment won't open during the wash cycle, how can I fix it?
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Nov 04, 2010 | Whirlpool Dishwashers
My washer (whirlpool duet) seems to cancel in the middle of load cycle. Most often the word "suds" is displayed. It is not the amount of detergent or the type because I use very little High Efficiency...
SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on
the drive motor. If "Sud" is displayed a potential suds lock is detected. This may
signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
ERROR CODES
DISPLAY EXPLANATION AND RECOMMENDED PROCEDURE
Suds
6 - 7
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a
Normal cycle without adding any detergent. This should clear the unit of the
excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and
Central Control Unit (CCU)
• Check/ Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Covered detergent dispenser not opening
The actuator needs replaced. You have to disassemble the door to find the problem.
Eric
Dec 23, 2009 | Dishwashers
Whirlpool gu2200 dishwasher, the detergent
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Aug 27, 2009 | Whirlpool GU2200XTSS Built-in Dishwasher
Inside detergent compartment door will not open during cycle
to much detergent clean it out and start over
Jan 31, 2009 | Dishwashers
Bosch diswasher detergent dispenser doesn't open during wash cycl
I've been told we can replace the dispenser. See AppliancePartsPro.com. Part AP2834000
Dec 24, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
2,454 people viewed this question
Top Dishwashers Experts
