Question about Dell OptiPlex GX60 (SFFDELL-C2G) PC Desktop
Gx 650 cannot boot from the usb
It will just install nessesaaaary files and then write' windows will shut down after that it will bring up theblue screen
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
Hi
My name is Sydney, the blue screen usually comes when your memory (RAM) is being used to the maximum and there is non left for other programs, or maybe your windows files are corrupt.
First of remove any software or hardware that you recently installed, cancel the installation of the necessary software so that you can do this without the computer giving you a blue screen.
If this does not solve your problem, reinstall windows and choose the upgrade option. if this does not help, you should just format your hard disk and this should solve the problem.
If the problem persists do not hesitate to contact me.
At your service Sydney
Posted on Feb 10, 2009
Tip
Compaq presario Wireless
These are the steps to make compaq presario f500 Wireless WORK!!!!
1.Download (password: kon-boot) Kon-Boot floppy image and extract the zip file to get FD0-konboot-v1.1-2in1.img filef.
2.Download latest version of UNetbootin and install
3. Run UNetbootin, select Diskimage, click the drop down menu to select Floppy and browse for the FD0-konboot-v1.1-2in1.img file.
4. Make sure USB Drive is selected for Type and the drive letter is the USB flash drive that you want to install Kon-Boot. Click OK. It should take a few seconds to finish installing Kon-Boot floppy image into your USB.
5.restart your laptop while the USB is in it.
6.When the compaq logo appears Pres Esc to bring the boot menu.
7.Chose your Flash Memory.
8. then press enter to chose Defult
9.press any key when u get the Kryptos Logic image.
10.then wait tell it finish
11.when u see again the Defult menu take the usb out and restart the computer by holding down the power button for 7 sec.
12. boot windows normally you will find the wireless BLUE and ready to work.
This is made By : Mohammed Abdulhadi (AKA) Hackezier Abdulhadi
Any copy of this article without approval will have legal consequences
Contact Me on:Hackezier@hotmail.com
on Oct 21, 2010 | HP Compaq Presario F500 F700 and G6000...
Tip
How to Boot and Install Windows 7 from a USB (even without an ISO file)
While searching in internet I found 3 ways of doing this thing. I will explain all of them here.
1st Method: (The simple one) * Requires a valid ISO image.
Download Microsoft's official tool to install Windows 7 from your USB stick.
Links below:
From CNET: http://download.cnet.com/Windows-7-U...?tag=mncol;pop
MS Store: http://images2.store.microsoft.com/p...B-DVD-tool.exe - Microsoft Store Info Here.
To install the Windows 7 USB/DVD Download tool:
  1. Click to open the Windows 7 USB/DVD Download tool installation file.
  2. When you are prompted to either save the file to disk or run it, choose Run.
  3. Follow the steps in the setup dialogs. You'll have the option to specify where to install the Windows 7 USB/DVD Download Tool.
Note: You need to be an administrator on the computer you are installing the Windows 7 USB/DVD Download tool on. The tool requires the Microsoft .NET Framework version 2.0 or higher.
2nd Method: (Reliable method, Supports multiple types of image files) Requirements:
Now insert the USB drive, run UNetbootin, and select Disk Image as ISO( or select the type of image file of which you have).
Browse your local drive for Windows 7 that you downloaded and click Open.
Now Select Type as USB and choose the drive.Once done, it will look like a bit similar to the screenshot shown below.
unetbootinmainwindows77.png Click OK and it will begin extracting all installation files to the USB drive. The whole process will take some time(10-15 minutes), so have patience.
Once the installation is complete, reboot your computer. Now while your system is starting up press the appropriate button(usually F1, F2, F12, ESC, Backspace, or Escape) to bring up Bios Boot Menu. Change the startup order to boot USB by default, usually you will have to press F6 to move the selected USB device on top. Once done, save changes and restart the system.
3rd Method:( Try this if both above methods are not working) Using Ultra ISO application.
1) Download the free UltraISO trial by clicking on this
2) Start UltraISO as administrator
3) "Burn" the iso image to the USB stick by following these steps
With UltraISO:
- Open the image of Vista/Win7 with UltraISO
- Under BOOTABLE tab choose WRITE DISK IMAGE
- Choose your USB stick under "Disk Drive"
- Choose a method (It's recommended to use USB-HDD+)
- Press Write
PS: Make sure to change your BOOT order in BIOS to boot from your USB drive first.
on Oct 06, 2010 | Computers & Internet
Msi cr700 media fail check cable
Hello, ihave same model MSI CR700 and have same problem, on booting up it says media failure check cable. Im try reinstal windows but freazed on instaling, Im try instal Ubuntu on USB stick and is working, I can see my disc but is like empty but yesterday there was all my files and no problem to opened files and pictures. what you thing problem in harddrive, cable, conector or motherboard. thanks
May 01, 2012 | MSI CR700-012US (816909061604) PC Notebook
I changed the hard drive in my ACER Aspire 5742Z-4459 and followed directions installing the recovery disks but when it down loads it can not go past #29 of 42 in software installion. It says installing...
Hi Keith,
You can easily install the Windows 7 in your computer after checking and ensuring the system requirements. You can insert the Original Windows 7 OS in your drive and reboot your notebook; this will make your notebook boot from the DVD. Follow the installation wizard and after the installation, enter the product key and then register the product at the Microsoft website.
For additional information please follow the steps below.
1. Hook up the hard drive, then insert the install DVD, and boot from the DVD to start the installation.
2. Boot your computer using the Windows 7 installation disc or USB flash drive. Turn on your computer, insert the Windows 7 installation disc or USB flash drive, and then shut down your computer.
3. Restart your computer and then keep on tapping the F12 to enter the boot menu.
4. Refer to on screen instructions to select either CDROM/DVDROM or USB CDROM.
5. Press any key when prompted, and then follow the instructions that appear.
6. On the Install Windows page, enter your language and other preferences, and then click Next .
-If the Install Windows page doesn't appear, please repeat step 3.
7. Once your on the Please read the license terms page, click I accept the license terms , and then click Next .
8. On the Which type of installation do you want? page, click Custom .
9. On the Where do you want to install Windows ? page, choose the partition that you want to install Windows 7 on, or click Unallocated Space if no partitions are listed, and then click Next .
10. If a dialog box appears saying that Windows might create additional partitions for system files, or that the partition you chose might contain recovery files or other types of files from your computer manufacturer, click OK .
11. Follow the instructions to finish installing Windows 7 , which include naming your computer and setting up an initial user account.
Hope it helps.
Thank you for using FixYa.
Jan 04, 2012 | Computers & Internet
I have a asus eee pc 900hd it is stuck on a stsrtup screen and i cant get it to da anything
Hi Amanda.
When it is like that you usually need to reinstall the operative system (Windows or Linux). Try first turning off the netbook and removing the internal battery for one minute. I don't think that will work.
You can also try accessing the RAM modules in the internal slot and checking they are well in place. Do this with battery and power off. Do not touch the chip contacts. electrostatic discharge from your fingers can damage them.
If that does not work, then the system must be reinstalled. The unit does not have internal DVD player. The system is reinstalled using an external DVD player and an operative system install disk or using an USB disk where the OS install files have been previously copied. The system setup is commonly done at any local computer shop for a small fee.
Regards.
Ginko
Sep 19, 2011 | ASUS Eee PC 900HD Netbook
I would like to use my usb flash drive to install and troubleshoot my windows xp operating system. My dvd cdrw drive is not working. I have an error stating that the explorasy.sys file is not there when I...
We are going to do this the easy way....you need a computer of course and one that has a working cd/dvd player, a flash drive and a windows installation disc. A recovery disc will not work...you need a windows installation disc.
Go to the control panel > folder options > click on the "View" tab, scroll down and UN-check the box the says "hide protected operating system files", now click the bubble above that says "Show hidden files and folders.
Now get out of the control panel and insert the windows disc in the drive.
Go ahead and insert the flash drive into a usb port and let windows recognize the device and load it. It will give the device a drive letter.
After the disc loads, it may appear on your desktop and say to install Windows....just exit the program but don't eject the disc. Open "My Computer" and look for your cd/dvd drive and right click on it. Choose "open" from the choices and a list of files and folders will appear. Select all the files except for a file that says "desktop
Copy all the files and paste them into the flash drive that you can find in "My Computer" The files from the disc will now be written to the flash drive. Once the copy is completed, the flash drive can now be used to boot the computer.
Insert the usb drive into the laptop that needs fixing and power it up. After the flash screen appears, tap the F12 key to bring up the multi-boot options. Choose USB drive and hit enter. The laptop will boot off the usb drive and initiate the Windows files.
Jun 30, 2010 | Toshiba Satellite 2415-S205 Notebook
Forget windowxp password
you can search for a password boot disk which will disable the administrator password.
There are dozens of these types of programs but one program I recommend is windows password reset 6.0
http://www.resetwindowspassword.com
Download the iso file and burn it to a disk to create the boot disk, that simple.
Configure your pc or laptop to boot in the cd drive,
Insert the CD and it would boot then just disable the password and restart.
Took about 5 minutes for the whole process.
Jun 08, 2009 | Dell Dimension 2400 PC Desktop
My dell gx-270 power keeps shutting down.
hmmm,
Dont worry just boot your computer using Bootable disk or windows installation disk, enter into Recovery console by pressing"R"
type the Administrator password if any or simply press "Enter".
At the command prompt type-"fixboot"
once done restart your computer normally.
Mar 25, 2009 | Dell OptiPlex GX270 PC Desktop
Dell optiplex gx 110
From the research I've done, it sounds like an issue with a (possibly corrupt) file in the video driver. Most people are recommending another video card be installed temporarily, to complete the windows installation. After that, you can uninstall the original video driver, shut down, then restart to have Windows reinstall the original video again.
Mar 11, 2008 | Computers & Internet
Dell OptiPlex GX60 (SFFDELL-C2G) PC Desktop Logo
180 people viewed this question
Alun Cox
