Question about Kenmore 24032\24036 Top Load Washer
Water leaking I have a Kenmore HEt2 front loading washer. It is leaking water on to the floor under the washer and making a squeaking noise.
  • 1 more comment
  • richmellor Jan 31, 2009
    I opened the front panel and the water stains are to the front and right side of the machine. Then I ran the washer on the delicate cycle, but there were no leaks so I still can't see exactly where the water is coming from. If the problem is what you describe, do I have to acess it from the back of the machine?
    I opened the front panel and the water mrks are in front right area of the machine. I ran the washer on the delicate cycle but there were no leaks. If the problem is what you think it is, do I have to acess it from the bak of the machine? I couldnt see any warter marks from the front on the drum. Thanks
    How do I check for a leak in the pump?
    Sergeant:
  • 250 Answers
f the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Jan 31, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The only component of a frontload washer that could cause water leak with a squeaking noise would be the impeller/drain pump. Checking would be relatively easy but messy.
Good luck and thank you for using FixYa.
  • 112 Answers
There is a rubber seal around the drum bearing underneath the washing machine.
If you look at it from underneath, you will see where the water is leaking because there will be water marks around the bearing, which is in the middle of the drum.
Good luck
  • Kenmore Master
  • 19,396 Answers
Check the drain pump hose, that is the most common reason for leaks.
  • Ginko
    Ginko Jan 31, 2009
    Star checking where the leak is coming from.
    Inspect the door gasket, if water is coming out from gasket, either one of the door gaskets is leaking , or machine is overfilling because of a bad water level sensor.
    A most common cause for leaks is the drain pump and drain hose, on the lower part of machine.
    Also inlet valve can leak, but to get in there you need to remove panel underneath and access to hose assembly.
Water flow on floor ?
my washer is not a front load or a fancy one, but my problem was also a leak coming from under the middle front of the washer. It was the water pump and once replaced, haven't had any more problems! It was a real simple fix, My husband was able to replace it in about 10 minutes, with a pump I found on ebay!! We found how to replace it on youtube!!!!!
Jun 07, 2014 | Kenmore 45081 Front Load Washer / Dryer
When filling my Kenmore washer to begin a load of laundry the water enters the tub like it is going to wash but immediately drains onto the floor and the "water sensor" never tturns the water...
This either due to a detached "water sensor"/pressure switch hose or a broken drain/leaking drain pump. Disconnect power then remove the screws securing the console to the top of the machine. Pull the console forward then up and lay it back on the hinges. The screws are located at the rear of the console, front corners of the console, or at the front corners of the console under the end caps.
Click on the link below for the detailed procedure in troubleshooting and repair of this leak problem.
Whirlpool and Kenmore Top Loader Washing Machines Leaking From the Bottom
Aug 20, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore 500 series top load washer. water on the floor during water pump out cycle. This does not appear to happen on prement press cycle, but does happen on normal cycle. Have no tried the heavy duty...
Could be a tub seal leaking (not likely), or water pump leaking (very common), cracked outer tub, leaking hose. You would really need to take washer cabinet off machine to be able to see where it's actually leaking.
Sep 30, 2017 | Kenmore 22422 Top Load Washer
Washer is leaking. If facing washer, water is on
probablly water pump or hose tilt machine to view where water is coming from
Jan 17, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore top-loading washing machine squeaks
Hi
Thanks for using FixYa. Please check if there are any sucked small clothes, safety pin, lint or debris in the water pump. If the pump is fine then the squeaking sound may be due to gear dogs in the agitator or bad gear case. The washer will spin and agitate at the same time. If the washer is still under warranty then do not try to open, repair or replace any part to void the warranty.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 13, 2009 | Kenmore 22422 Top Load Washer
Leaks water
Probably a bad water pump. That is were the Kenmore usually leaks.
2 screws on the top panel right and left sides.
Remove these screws, tilt the control head backwards.
Remove the wiring harhess connector.
Remove 2 clips holding the cabinet to the back panel.
Remove the cabinet by pulling forward.
Pump is attached to front of motor.
Feb 21, 2009 | Kenmore 24642 Top Load Washer
Kenmore washer, elite 70 series is leaking water on floor
the hose from the drum to the pump, and from the pump to the drain, are at the front,
Movement of the drum during wash cycles, wears the short hose between drum and pump and it develops cracks, eventually a wash load of any size will finally cause one of the cracks to penetrate through the rubber, and constant drip occurs.
Its an easy fix, no more than screwdrivers needed.
the local parts guy will have the hose, even if it is labelled ge frididaire whirlpool the same hose is common to many makes and models
  • turn off water unplug washer
  • pop the endcaps off the control panel, and completely remove the phillips head screw under each endcap dec762a.jpg
  • lilft the control panel ~1inch and flip it over the back of the washer,
    (do not dislodge the water level sensing hose or we'll be back to fix it later, hinges are plastic, dont bust em)
  • remove the two brass clips under the control panel
    (note position for reinstall)
  • remove lid switch connector
  • lift entire body up ~1 inch and remove forward
  • motor pump hoses gearbox are now exposed.
examine hose from drum to pump, and from pump to cabinet rear,
replace cracked and crazed hoses.
reassemble in reverse order
Oct 12, 2008 | Kenmore 24032\24036 Top Load Washer
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
56 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
