Question about Samsung HP-R5072 50 in. Plasma HDTV
Limited channels my samsung only will pick up 13 channels and i have cable it want pick up no other channels
    President:
  • Samsung Master
  • 1,779 Answers
If you have two inputs- Cable and Digital, make sure it is in cable then proceed to AUTO PROGRAM.
Posted on Feb 04, 2009
TV won't pick up channels 7-13
These are what once were VHF channels and are still mostly assigned to local stations.
You didn't mention the source for your received signals, if antenna, cable or satellite and it does make a difference as to the possible source of the problem.
If you are receiving via antenna, then the problem is within the set itself. If from one of the other two sources requiring a 'box,' then the problem is likely within the cable or satellite box that is between your incoming signal and the set.
Jul 29, 2012 | Magnavox 39" LCD 1080p HDTV 39MF412B -...
Channels only go up to 14 then bluscreen after that, i have basic cable that should got to channel 64, i am using universal remote so i have to fix from tv
Check antenna cable setting in menu. If you have it on antenna and cable plugged in, you will not pick up anything past channel 13. Change it to cable setting in menu.
Nov 27, 2011 | Prima CV2011 TV
I get channel until #13 how does i get the other chnnel
TV's of this era have two modes that the tuner can work in. One is the AIR mode and the other is CABLE. In the air mode the tuner picks up only "off air" frequencies,... and up to channel 13 they happen to be the same as cable channels 2 thru 13. If you are using cable you will need to go into your on screen menu and find where to change the tuner from "air" to "cable" to get channels above 13. Older sets had a switch on the front and sometimes the back to select the tuner mode.
Aug 14, 2010 | Curtis CM19033S 19" TV
Can't pick up all available channels
Well, remember that in USA all olds tv do not can receive signal because the new signal transmitting is in high-definition and old equipment do not receive that kind of signal.
Mar 27, 2010 | Zenith SY1324S 13" TV
Skips past all channels after 13. CableVision
I don't know the exact step to set it because I don't know you model TV. When you go to menu set channels it should give you the option to choose cable or air. If you pick cable all your channels will be in VHF which is what you want. If you pick air the first 13 channels will be VHF and the rest will be UHF which cable don't work on. After you pick cable then auto program and you should get all your channels.If this helps you and I hope it does give me a vote please.
Mar 04, 2010 | Televison & Video
I can only get the first 13 channels. I am trying to program the plasma for viewing but I can not pick up any more channels.
In your channel setup menu there will be an option for air/cable selection.Right now you must be on "air", that why you get only the 2 to 13 channels
You want to select "cable" and then rescan/autoprogram your channels. Hope this will help .
Dec 02, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
TRutech 15" LCD does not pick up all channels
Check your TV settings and make sure your tuning is set for cable (may say "cable" or "CATV"). Right now you'll probably find it set for "air". If the TV is set to tune off-the-air, cable channels 2 through 13 work normally, but above that they aren't detected. Once you set the tuning mode to cable, rescan channels and you should have them all.
Apr 01, 2009 | TruTech PLV1615T 15 in. LCD Television
Samsung plasma cable problem
your digital or anolog board is bad needs replaced can find on ebay if you can get part #
Jan 23, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Samsung HP-R5072 50 in. Plasma HDTV Logo
Henry  Thomas
Henry Thomas
