Question about Ovens
Turning oven on Indesit K645R V/G
I cant turn my oven on. The stencil icons have worn away and someone kindly cleaned my cooker for me but moved the oven knob and I now cant get it to go on as I cant find the 'little hand' symbol. The fan and oven light goes on it just wont turn the heat on
SOURCE: Neff u1271 oven not heating
Found the fault. It's the heat ring in the main oven. MAKE SURE THE MAINS POWER IS OFF PRIOR TO COMMENCING THIS WORK!!!!! 1.Simply remove the four screws that fix the fan surround in the main oven. 2.Remove the rear cover fixing screws and remove the rear cover. ( the cable passes through this so just rest it to one side ). 3.Remove the two push on spade connectors from the heater element ( positioned just down and to the right of the fan assembly ). 4.Remove the four heater element fixing screws from inside the main oven. 5. The tricky bit. . . There is one more fixing at the top of the fan in the main oven. I could not get the fan off its spindle, but the next step sorted this out. 6.Remove the three fan fixings from the rear of the oven. This allows the fan to wobble/move enough in the oven to remove the final heater fixing screw at the top of the fan. 7.Pull the heater element into the main oven. No doubt it has a very grey and flakey appearance to part of it! 8.Buy a new one and replace it in reverse order, remembering to replace all fixing screws as you go. 9. If you forget which way the cables on the heater element go, the one with the red marks on it goes to the left as you look at the back of the oven from the outside. ( nearest the fan assembly ) I know this all looks a bit long winded, but it really is quite simple if you follow the notes above! Hope this helps someone. Might just save a ridiculous call out charge from the professionals!!!! Best of luck, Keith.
Posted on Aug 18, 2007
  • 3463 Answers
SOURCE: I have an AEG cooker but the marking around the cooker knobs have
You need thermostat knob and main oven control knob.
Posted on Nov 20, 2008
  • 3463 Answers
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Posted on Dec 27, 2008
  • 3463 Answers
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Posted on Jul 01, 2009
  • 12 Answers
SOURCE: indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Posted on Oct 24, 2009
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Apr 15, 2015 | AEG Ovens
Indesit cooker
I would contact indesit on there tech help line .Its on line on there site
Apr 21, 2017 | Ovens
Smeg cooker flashing 88:88, and wont turn on. please help
goto ( click on services
Dec 21, 2017 | Smeg Ovens
Instruction manual for stoves newhome EFa600H fan oven
hi Ali, do you have any photos for this cooker EFa600H? I need front of this cooker. because i have in my new home but i can't used this apliance because all numbers ale clean, someone clean this oven very very strong and remove all signs:)
cheers, marce
Oct 04, 2010 | Ovens
No power in oven
If it has a digital or anologue timer, make sure it is set on manual, or the oven will not work.
Dec 05, 2008 | Ovens
Nov 19, 2008 | Ovens
Electrical connections on indesit cooker
Is it just a 2 wire connection element?
Feb 29, 2008 | Ovens
Ovens Logo
181 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
