Question about LG LMH1017 Convection Microwave Oven
I dont know how to use my microwave oven for cooking food.
I dont know how to set temperature and cook in microwave ovan
Posted on Feb 26, 2009
  • LG Master
  • 8,973 Answers
Please reply back with your brand and model number so we can help you.
We should be able to point you to the owner's manual.
Posted on Jan 31, 2009
  • Mrs. khan Dec 15, 2011
    PLZ guide me how to bake in west point microwave oven
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: microwave oven not heating
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diodeand capacitors can be tested. The capacitor must bealloweddischargebefore testing, or you risk to get electrocuted, evenifpower is off.Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Apr 27, 2009
heatman101
  • 43501 Answers
SOURCE: Cooked food is not getting heated in my microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hhg
Posted on Sep 30, 2010
Why does it keep running
I have a microwave at work that keeps running after the cook time because it uses the extra time to cool the food so it just spins around the food and the light is on. Check the user manual to see if this is the case with this particular microwave oven.
Jun 05, 2015 | Microwave Ovens
Microwave not cooking food at all,motor sounds louder
This indicates the magnetron has failed, the most expensive part in the microwave oven.
Jul 11, 2012 | GE Microwave Ovens
I have the Dacor DCM24 microwave and if the table does not spin will the microwave still cook food. I think my turn motor is bad, but wanted to know if I could cook food without it?
Yes! it will continue to cook food, the only difference you may end up with cold spots in the food, rotate plate once or twice to reduce this.
May 30, 2012 | Dacor DCM24 Convection/Microwave Oven
How to set temperature in Samsung microwave. 160 c means ? watts.
They're totally non-interchangeable as they're two totally different ways of cooking.
There is no correlation at all between a temperature setting used by electric and fan ovens and the microwave power level, there's not even a rule of thumb. For microwave cooking, the fat, sugar and water content of any given food item as well as the mass and shape are what determine cooking times and microwave power levels, and not all foods can be safely microwaved as high fat/sugar content foods may catch fire.
Jul 06, 2011 | Samsung MW4699S Microwave Oven
Small amount of white smoke coming out of kenmore convection microwave in oven mode
That is usually caused by a build up of fat from microwave cooking on the heating element. It will clear under normal conditions and return if one cooks foods like bacon etc, un covered to prevent splashing of the food that is being cooked.
Hope that helps.
Oct 31, 2010 | Kenmore 63793 Convection / Microwave Oven
Cooking
You just place in the food product into a non metallic bowl and set the timer and press start. Not sure what else you are wanting to know.
Let me know how this works out for you.
Benjamin
Apr 26, 2010 | Kenmore 64002 Microwave Oven
GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave still runs but is not cooking food
Sounds like a bad magnetron, i would replace the magnetron, Capacitor and Diode at the mag assembly, to be honest it will cost you more to fix than a new one.............
Sep 10, 2009 | Magic Chef CMV1000B Microwave Oven
Little plastic ring with wheels broke in several places
the purpose of the turntable is to more evenly cook the food. it shouldnt effect the mics ability to cook, just might take a little longer to thoroughly cook food
Apr 21, 2009 | Emerson MW8625W Microwave Oven
GE microwave
If the mocrowave still working, I wouldn't worry about operating it. If you want to have some peace of mind you can buy the paint and do it yourself. Go HERE to get the paint that is specially for microwaves use.
Feb 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
LG LMH1017 Convection Microwave Oven Logo
219 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
Will Halftowaite
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
