Question about Vacuums
I have just purchased a new Nilfisk vaccuum cleaner 150 extreme and used it for 5 minutes and switched it offf. When I tried to restart the machine it would not start. I cannotg et it to restart-how to i solve the problem -the power light is on
  • 276 Answers
If you're just purchased it I suggest you need to check where your local Warranty Agent is and take it there for a service. Since this model has an electronic switch (do the lights flash on and the middle one stays green when powered on at the power point?) you may need to get that checked out.
BTW there is a motor protect fuse that shuts the motor off if it overheats. Once the motor cools down it should have been fine. Check for blockages in the hose as sometimes things get stuck in the handle.
Posted on Feb 24, 2009
Hi I have a nilfisk alto that has not been working properly. It has not been spraying the water
Alto nilfisk vaccuum is not spraying water , a highpressure washer do you mean not a vaccuum .
But If it's an alto nilfisk blue pressure washer on the vaccuums topic it must be the bypass / autostop on the pumphouse its internally a point where a microswitch is placed and depends on the type of washer by a problem with the parbak ( a parbak is a oring/ with auxiliary kevlar ring(s)) that can hang on lime, but on an other model there are 2 springs on the bypass and one of them the great spring is broken or only hanging on lime but thats rare if it is.
I don't know if there are vaccuums with water spraying only for remove dust.
Feb 15, 2017 | Nilfisk Vacuums
Why is red light on my Nilfisk Orbit vacuum cleaner on ?
[PDF]Nilfisk GM80 and GM80i Vacuum Cleaner User Manual ...
www.sylvane.com/media/.../nilfisk-gm80-vacuum-cleaner-user-manual.p...
Troubleshooting. Loss of Power. 5. 6 ... CAUTION: This Nilfisk vacuum cleaner or any other vacuum cleaner is not to be used in explosion-hazardous areas, as ..
Sep 19, 2015 | Nilfisk Vacuums
My Nilfisk GU305 cuts out after a few minutes use
You are probably right. There is not enough air flow around the motor. It uses the air from the vacuum as the cooling air.
There is a secondary filter after the first filter bag. You may think the bag is not full and don't think you need to change. Sometimes the material you vacuum is so fine that it will clog the filter bag. I've done it vacuuming sheetrock sanding dust. Then just below the main filter is the secondary filter. Depending on the age and amount of use, there could be other problems. Motor brushes about to fail. A wire connection that separates as temperatures rise. Then reconnects when "cool". Plug end may be a problem. Its connection to the switch. The switch it'self could be.
Mar 21, 2015 | Nilfisk Vacuums
Nilfisk 150.2 willnot dispence soap when jetting
i have some bad news for you. when using soap not recommended by the manufacture, and you use the machine and use another type of soap or cleaner after you do not run water through the machine to clean the tube and sprayer out of soap the soap drys up and kluges the tubes and the sprayer, and you have to take it to be repaired or buy a new machine. i can test to that the hard way i loaned mine out and it was returned dirty and soap was dried up inside the tube and jets, look at the tube if you see dried up bubbles than the machine needs to be repair and service, service center , sew and vac one place vacuum dealer
Feb 28, 2015 | Nilfisk Vacuums
Change front wheel on x300
The front wheel on a Nilfisk Extreme 300 is changed by removing the 3 screws inside the bag chamber. From memory they are a torx screw driver size 15 or 20. Basically remove the bag and take out the 3 screws in the middle of the chamber - the wheel will fall off once you lift the machine up. If you need to buy a replacement wheel you can find one here.
Nov 10, 2013 | Nilfisk 11730410 Micro Filter Polyester,...
Nilfisk Extreme 300 does not always respond to the remote trigger on the handle
The Nilfisk X300 has a battery in the handle piece it would be worth simply replacing the battery. If that does not solve it you may need a new Nilfisk X300 Handle. It is possible that it is the receiver i teh machine but to be honest these are a pretty hard machine to work on and the circuit boards are all interconnected, this is a repair for an experienced player.
Sep 03, 2011 | Nilfisk Vacuums
Hi my nilfisk alto e140.1 has just cut out i have changed the fuse its not that could someone please help because i have borrowed it off a friend :( helen....
Hi Helen,
I checked the owners manual. Here are some things you can check:
The thermal sensor has shut it down. The manual says to let it cool down for 5 plus minutes, then try it again. I imagine you've tried that already, so ....
The nozzle could be partially blocked. The nozzle MUST be detached in order to clean it. Use something as long as the nozzle, like a stiff wire or needle like object, to clear it. Then flush it backwards with water.
Since the fuse blew, try the machine without the extensions hose or use a little higher rated fuse or both.
The pump/spray gun is leaking.
If none of these works, please reply back.
I hope this does work. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 06, 2011 | Nilfisk 350-01 Wet Washer
When vacuuming dust does not go into bag but goes all over the place.
Used an elastic band to tighten bag onto nozzel.
Sep 27, 2008 | Nilfisk Vacuums
Last year my wife and I bought a new Dirt Devil Reaction All Surface vaccuum cleaner to replace the older Platinum Force. After using it a couple of times the new one gets clogged with dog hair easily and...
Greetings jettin_us,
Normally you can contact the store you purchased the unit at, and if you paid with anything other than cash, they may be able to retrieve your receipt for you.
Once you get the receipt, if you still fall inside your 1year factory warranty, I would suggest contacting Dirt Devil for further assistance. Their contact number is 800-321-1134.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jul 29, 2008 | Vacuums
Miele S326i Vaccuum cleaner hose broke
any miele warranty center can help you with ordering a new part, look on line for close center. Or try main office.
Mar 13, 2008 | Vacuums
Vacuums Logo
227 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
