Question about Canon PIXMA iX4000 InkJet Photo Printer
Cannot fill a3 sheet
Hello
every time I choose the size "A3"before I send the signal to the printer and filling the image edge to edge...................I end up with an A3 sheet with an A4 size print at one side of the sheet
how can I get the printer to print a full size A3 sheet ?
Thanks !
regards
Lee
Have you set up the page as A3? If so, should be ok if you set the printer paper size to A3. If you set up the page on A4 you will need to tell the the printer to 'scale to A3' and it's best to say you want to preview before printing
Posted on Mar 06, 2009
HI MY DESKJET 9800 WILLNOT FEED A3, IT JAMS ON THE LEFTHAND SIDE EVERY TIME, I HAVE LOOKED TO SEE IF ANYTHING IS OBSTRUCTING DUE TO BEING IN STORAGE FOR A WHILE. A4 FEEDS CORRECTLY, BUT CANNOT FIGURE OUT...
If A4 is ok but A3 jams then I would have to say there IS something hitting the paper. Try another A3 sheet and when it jams, pull the paper back out (after the printer is switched off) very slowly. When its out take a look at the leading edge and you will see a kink in the edge of the paper. Now place the paper back in the input tray and look at where the kink is in relation to the machine. That will tell you exactly where the obstruction is.
I hope you understand what i am trying to say.
Jul 10, 2011 | HP DeskJet 9800 InkJet Printer
Tip
Tips to Choose an A3 Printer
When it comes to printing, there is a wide range of printers available. Primary <b>A3 printers</b> to print pages that are double the normal <b>A4 page</b>. <b>A3 pages</b> is useful when you want to print a large amount of data or a poster in an organization. When you want to make a difference with your A3pages, you should have the right <b>printers A3</b>. While choosing your<b> A3 printer</b>, there are some things to keep track of how you choose.<br /> <br /> There are several types available in the market. You need to know what you want in your<b> A3 printer</b> that you will use. When you have a clear idea of how to choose a<b> printer A3</b> becomes really easy for you.<b> A3 printer</b> comes with many features such as <b>A3 printer scanner</b> added, direct printing from <b>USB flash drives</b>, using the <b>A3 printer</b> and a fax with <b>A4 printer </b>as a copier and even a Wi-Fi and <b>network interface</b>.<br /> <br /> With so many options available, you need to know how to choose an <b>A3 printer</b> to make a wise investment. Even though prices have been reduced, they can be very pricy. Instead of buying an <b>A3 printer</b> that has all the integrated features, you can choose only those needs that you need. This will save lots of money.<br /> <br /> <b>A3 printers</b> are easy to maintain, you must be prepared to do regular checks. If you do not want your<b> printer</b> needs servicing often, so please select the top sustainable. They require frequent maintenance or filling of cartridges, as they will last far beyond the normal flow of <b>printers</b>.<br /> <br /> How to choose the<b> printer</b> is a very important aspect, especially when there are so many options available. Each printer has its advantages. You may have the same characteristics of the second<b> A3 printer</b>, but it could fit right, if you want, within your budget and needs. In addition, you must decide whether it should be for commercial purposes or common house hold. It is <b>A3 printers</b> with different capabilities, such as the number of pages per minute, so in the light where you need a<b> printer</b>, you should opt for an<b> A3 printer</b> wisely and make best use of it<br />
on Feb 01, 2011 | Office Equipment & Supplies
Send a A3 to print and it prints to A4...how to change this
when you give print command, go in printing preferences select paper size A3 and out put size A3. then printer will print on A3
Apr 11, 2011 | Office Equipment & Supplies
I cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
Dec 31, 2009 | HP DeskJet 1280 InkJet Printer
Size reduction from A3 to A4
put the A3 original on the glass.
press reduction button.
make sure you have A4 loaded into the drawer.
select that drawer.
off you go.
Nov 19, 2008 | Canon IMAGERUNNER 6570 Copier
Canon Imagerunner 210S - A3 error
A3 is a metric size paper. The document you are trying to print must have been formated for metric size paper. When you print select "Fit to printer margins" De-select "Choose paper source by PDF page size" and select the proper page size and source.
Jun 09, 2008 | Canon imageRUNNER 210S Copier
A3 Printing
Put A3 in the paper tray and select reduce and enlarge and set to 141% this is A4 up to A3 then press start this should help.
Thanks J
Oct 02, 2007 | Sharp AR-161 Laser Printer
Canon PIXMA iX4000 InkJet Photo Printer Logo
256 people viewed this question
old marine
old marine
