Kenmore Series 70 washer was dripping into bowl after cycle completed. Then, one day it overflowed while filling up to begin cycle.
  • 15,935 Answers
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
Kenmore 70 series washer over fills
there is a plastic tube that runs
from the tub to the overflow switch in washer. If this develops a hole in it, air
pressure is not applied to the switch to shut it off. good-day !
Dec 17, 2011 | Kenmore Washing Machines
Kenmore 70 series , overfill water dose not stop at set fill levels
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Jan 16, 2010 | Washing Machines
Washer keeps filling up with hot water
Hi
If your washer is overfilling, check these: Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Kenmore Washing Machines
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
Washer keeps filling with water...
you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer
not normally. Sounds like the level pressure switch is not operating.
There is a chamber on the side of your outer bowl...this has a tube attached heading off to the pressure switch.
Check tube for chaffing; check for blockage in chamber and tube assembly;
if none of the above could be the pressure switch this is thou.
Jan 02, 2008 | Kenmore 24032\24036 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
