Question about Maytag Neptune MDE5500AY Electric Dryer
My neptune has no heat. Trying to pop the top up to take a look and not sure how to get the thing opened????
You take off the door screws and the screws on the other side. This will allow you remove the front of the machine. Pull forward at the top front, it will pull out and then you can lift up to get the bottom out of some clips. You will have access to most of dryer from here, but if you want to pop the top, it pops up like a car hood. There are 2 brackets/bolts in the upper corners that need to be removed. You can then pop it up.
Posted on Feb 07, 2009
Maytag Neptune gas dryer does not produce heat
Could be a numerous amount of things. Most common is a blown thermal fuse or high limit safety switch has a open circuit rather than a closed circuit.
Apr 15, 2015 | Maytag Neptune MDG5500AW Gas Dryer
WHY DOES MY NEPTUNE MATAG DRYER MDE5500AYW NOT HEAT ...AND WHERE ARE THE THERMAL SWITCH, HI LIMIT THERMOSTAT, AND HEATING ELEMENT?
All those parts are in the bottom front. TURN off the power! then open the front door and remove the 4 screw's, 2 on the hindges and 2 on the other side. Then you can close the door, and pull from the top edges of the front panel(sometimes you need a thin screw driver to free the front) the front panel will tilt forward and then you can lift it off. You will need a Ohm meter to check those parts for continuity. Make sure you remove the wires from the part you are testing.
Sep 30, 2014 | Maytag Neptune MDE5500AY Electric Dryer
No heat coming out to dry clothes, can the heating element be replaced
yes, it is located on the back right inside of the dryer.
1) unplug dryer
2) open door remove screws
3) with a flat tip screw driver pry gently up on the top corners it will pop
4) move front panel forward and disconnect door switch
5) sit panel aside
6) lift top lid of dryer 90 degrees it has clip/hinged on back
7) look to the right back of dryer, it looks like a spring in a metal box disconnect and replace.
Hope this helps Tim
Sep 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Its a gas neptune with dryer top. It quit heating so I reset it to factory defaults using the technical manual and the heat came back on but only for one cycle, Top heat works fine. Bottom control panel...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
How do i open the top of this washer?
NO THERE ARE SCREWS THAT HOLD THE FRONT ON AND HINGES.REMOVE THESE THEN YOU WILL SEE A SCREW ON EACH SIDE FOR THE TOP. DONT LIFT UP UNTILL YOU REMOVE THE DISPENSOR COVER.
Mar 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Dryer running not heating clothes
You have a bad heater element. Pop the top and check it out
44f1253.jpgUse a putty knife to pop the top so you can access the heater mounted in the rear.
Apr 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer won't rotate after blower wheel replacement
The dryer belt may have broken or come off its pulleys. Pop open top of dryer or rear vent door to look inside to see if this is your problem. Let me know if I can help, Thanks Sea Breeze
Mar 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer too hot...no cool down
no the thermal fuse has nothing to do with that,although it will open again if too hot and that may be why it opened in the first place.most high heat ,long dry times are the house ducting.try this experiment.remove your dryer from the house ducting and dry a load[it wont hurt a thing]if not as hot,then get that ducting cleaned.if still hot then make sure the inner dryer air ways are clean.your blower is spinning fine[not broken on the shaft]and also check with ohm meter,or visually that your heating element is not shorted to ground[then it by passes the cycling thermostat.if all those things good and still getting high heat i may replace the cycling thermo.but as a repairman i did not have to do that very often.most of the time it was the other possibles. i hope this helps abit God bless ,tom
Feb 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My Neptune top-loader washer,
Evidently the "OP" code indicates the lid is "open". Solution in my case: I had to replace a wire on the lid switch that a
had rusted and no longer connected to the switch resister.
There is a magnet in the left, front corner of the plastic lid insert. When the lid is closed, this magnet sets on top of the tan colored plastic pad on the left front top of the base washer unit. When the lid is closed, the magnet activates two, small metal rods on each end of a resister within the white. You have to pop up the top of the washer base to gain access to the switch, Good luck,
Aug 29, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MDE5500AY Electric Dryer Logo
48 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
