Question about Acer Computers & Internet
    Problem Solver:
  • 4 Answers
Check ur mic in volume control its may be on boost mode
Volume.>>>>>>mic>>>>>>property>>>>>boost>>>>uncheck it
Posted on Jan 31, 2009
After 90 minutes or so of perfect play back... the picture became very distorted (static) and lost the sound completely. I manually cleaned the head. Distortion is less, sound still out.
please try to clean the cassette tap running path like capstan motor shaft and the inclined posts and the pressure roller Etc, check the roller for loose if any.
Feb 18, 2016 | Sony Handycam CCD-TRV40 Camcorder
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
My rca tv has a distorted picture and a really high pitched buzzing sound
Problem is in High voltage circuit and likely either the high voltage transformer or a connection right under or around it.
Jun 16, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
The reset button disables your pitch control and allows the turntable to rotate at TRUE "0" (zero). FYI, these turntables were NOT made for DJing. They were made for radio, studio, and high end home use. They became DJ turntables, because they were perfectly built for the trade. So, the pitch reset button is more of a function best suited for radio stations or a producer who needs to record or play at a true zero speed.
Now, on to your question...
More than likely you just have to calibrate your pitch control. There are various videos on YouTube on how to do this properly. Just do a search CALIBRATING 1200s or similar. FYI, all the Technics SL1200/1210 MK series are the same inside. MK2, MK3, MK5 - so don't worry if you only find videos on calibrating MK2's or MK5s - works the same on all the models.
Apr 01, 2008 | Technics SL-1200M3D Turntable
Awful High-pitched Noise and Echo Feedback
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Jan 17, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
Sound from monitor speakers distorted and high-pitched
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 16, 2008 | Computers & Internet
Steam Button
Your iron pump is faulty the high pitched sound is normal.
Nov 27, 2007 | Rowenta Perfect Iron
High pitch ringing noise and picture distortion
Sounds like the capacitor that goes bad just before the hIgh Voltage transformer goues bad. If i were you I would call an authorized RCA repair Shope and see if this is going to cause more damage to your set in the future.
Aug 25, 2006 | RCA HD52W59 HDTV Projection Television
Computers & Internet Logo
91 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
