Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Nikon D40 will not focus when shutter pressed 1/2 down
I am using a Nikon D40 with a Nikon DX AF-S NIKKOR 18-55mm 1:3.5-5.6 GII ED lens.
Have had the camera for 1.5 years, and it has worked just fine with the exact same set up until now.
Problem:
When i press the shutter button half way down (no matter what setting the camera is on) it does not make any mechanical focusing sound and (obviously) cannot focus into any target. I cannot take any pictures due to this.
  • 3 more comments
  • rblancha Feb 07, 2009
    Yes, the physical AF switch that is located on the top left of the lens is set to A.
  • MiniLaura Feb 22, 2009
    I'm having the same problem, too. And yes, I made sure the lens was on Autofocus. When it is having problems focusing I can hear a faint clicking sound like it IS trying to AF but is unable to do so. When I switch to MF, I can turn the ring freely and focus manually, but I want the AF to work!
    I'm wondering if the problem is with the lens or the camera since the AF motor is in the lens not in the D40/x body. I've switched to another lens to test this theory.
    However, the problem does not happen all the time, so I have problems reproducing it. If I do have the problem with the new lens, I'll try cleaning the contact as kalansing has suggested.
  • drderekp59 Mar 07, 2009
    i have the same problem. sometimes when i first pick up my camera the autofocus does not move and makes a faint clicking sound. if i switch it to MF, turn the the ring and switch it back to AF it will start to work normally, although sometimes i have to repeat this 2-3x before it works. after that the camera works normally for as long as i use it. does anyone know what is causing this? the camera is only about 2 months old. is this a sign of trouble to come and should i look into having anything done to it while still under warranty?
  • evillafane Mar 16, 2009
    I had the same problem. Sent the lens to Nikon (under warranty). They repaired it, but would not be explicit as to the problem. I believe the changed the motor. It came back with a more silent, faster focusing... until it happened again. The problem apparently appers after using the lens repeatedly while using the built-in flash or the 400.
  • michael galang May 11, 2010
    have you set the AF switch on the lens to 'A' ?
  • 137 Answers
Has the lens stuck up? put it temporarily on 'M" and try to turn the focus ring. this should be freely turning;
otherwise you may want to check the camera body to lens electrical contacts (silver).. a small dab of alcohol to a q-tip.. make sure its not that wet..then try to clean the contacts.
Posted on Feb 09, 2009
Autofocus on Nikkor 18-55mm lens doesn't work
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
Jun 08, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
I have a Nikon D3100 and want to buy a zoom lens 70-300.Please help I am confused is a Nikon AF Zoom-Nikkor 70-300mm f/4-5.6G compatible? And is it automatic focus?
That lens will work with the D3100, except for the autofocusing. In order to autofocus with the D3100, you need AF-S lenses, such as the AF-S VR Zoom-NIKKOR 70-300mm f/4.5-5.6G IF-ED or the
AF-S DX NIKKOR 55-300mm f/4.5-5.6G ED VR.
May 22, 2011 | Nikon Cameras
My lens isn't focusing as fast as it use to and is noisy when focusing now. What could the problem be?
Assuming this is on a d40/d40x or similar camera without a motor in the body. What is happening is your lenses motor is wearing out and is no longer as functional as it once was.
Feb 05, 2011 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Using a Nikon D40 digital slr with a AF-S DX Nikkor 18-200 1:3.5-5.6 G ED lens I was previously able to autofocus bun now am not. Can you suggest reasons why this may be?
Please check if the Autofocus-switch on your lens is set to M/A. Also check if the Autofocus on your camera is switched on. For detailed information about your cameras autofocus, please check this site: http://www.kenrockwell.com/nikon/d40/af-settings.htm
Jul 18, 2010 | Nikon D40x Digital Camera
Nikon DX AF-SNIKKOR 18-55MM 1:3.5-5.6G11 ED auto focus don't work
If you're looking at the camera without a lens on it, there should be a little flat protrusion in the lower left. Make sure that it is protruding and not obstructed.
Dec 19, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Can Nikon D60 work with 18-200mm f/3.5-5.6G Zoom Nikkor
Yes, it will work just fine. I have this lens and my father has basically the same camera (D40) and it works just fine with this lens.
Feb 22, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Nikon D80 Autofocus problem
sir, replace ur lens image reading sensor
Apr 06, 2008 | Nikon D50 Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
885 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
