Question about Woods Upright Freezer MU07W
Temperature dial - which way is for colder?
Woods refrigerator Model R17WCA, lost manual
  • little mm Mar 08, 2009
    Which diagram is for defrosting - is it the igloo or the snowflake!!
    Problem Solver:
  • 10 Answers
The higher the number, the colder.
Posted on Feb 07, 2009
Fast Freeze (some models):igloo
This setting causes the freezer to run
continuously, driving the freezer temperature
to the coldest possible temperature. To
activate, turn control knob to
which is the coldest setting. Use this
feature just before adding large amounts of
unfrozen foods. For best food quality, do not
exceed 3 pounds per cubic foot. Return to
your normal setting after 24 to 48 hours.
Posted on May 20, 2010
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
There is no power fridge will not run
Put more coins in the electric meter! lol
Check socket with working desk lamp
Check fuse in freezer plug
Apr 02, 2014 | Woods Upright Freezer MU07W
Which way is colder on the temperature dial?
Turning thermostat clockwise lowers the operating temps.
Mar 14, 2014 | Black and Decker USA Black & Decker 3.3-cu...
What is the setting for quick cold for the freezer?
Just set your thermostat to the colder position. If you still face the same problem, you need to conduct service maintenance of your freezer. It may dirty, run out of refrigerant, leaks problem, sensor problem etc.
Jan 12, 2011 | Woods Freezers
Unsure how the temperature dial goes. Is it l. or r. for colder?
Hi Normally temperature dial has at left maximum temperature while right is minimum temperature.
You can feel ( hear ) actually the sound of motor/compressor when it is run. Running motor will produce low temperature. By this you can decide where the set point should be made
Sep 09, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
I need to learn how to control the tempature setting
The temperature controls are located at the top front of the refrigerator or freezer compartments.
The recommended setting should be correct for normal household refrigerator use. The controls are correctly set when milk or juice is as cold as you like and when ice cream is firm.
Wait 24 hours for your refrigerator to completely cool before adding food. If you add food before the refrigerator has completely cooled, your food may spoil.
NOTE: Adjusting the refrigerator and freezer temperature controls to a colder-than-recommended setting will not cool the compartments any faster.
If the temperature is too warm or too cold in the refrigerator or freezer, first check the air vents to be sure they are not blocked before adjusting the controls.
To turn Off/On:
Style 1 Press the freezer down arrow touch pad until a dash (-) appears in both the refrigerator and freezer displays. Neither compartment will cool.
Style 2 Turn the freezer control to the word Off. Neither compartment will cool when the freezer is set to Off.
Energy Saver option (on some models)
The Energy Saver option turns off the heater which helps to reduce moisture on the door hinge seal. The refrigerator uses more energy when Energy Saver is off.
Press the control to On to save energy when the environment is less humid.
Press the control to Off when the environment is warm and more humid, or if you notice moisture on the door hinge seal.
Adjusting controls
If you need to adjust the temperature in either the refrigerator or freezer compartment.
NOTES:
For Style 1 control, press the up and down arrow touch pads; for Style 2 controls, turn the dial to adjust the temperature.
Except when starting the refrigerator, do not adjust either control more than one setting at a time.
Wait 24 hours between adjustments for the temperature to stabilize.
Hope this guideline will helpout.....
Aug 10, 2010 | Traulsen Reach in Freezer - G22010
Lost Manual on My Frostless Freezer
You can try this site to look for the user guide of your Freezer
http://www.retrevo.com/.
Hope this help.
Aug 25, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Woods Upright Freezer MU07W Logo
3,282 people viewed this question
Top Woods Freezers Experts
Dan Webster
Dan Webster
Sal De
Are you a Woods Freezer Expert? Answer questions, earn points and help others
