Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitro 36" HD TV
My TV sceen picture leaning down to right. Is there horizontal button or verticle button.
  • Sony Master
  • 12,061 Answers
There is a circuitry problem with the scan control, this is a job for the "Shop" as I always advise get a firm "Quote" B4 prceeding with any fix... Generally these days there is no Horizontal/Vertical Hold, as such, it is all done by the Compter Chip inside.
Posted on Jul 31, 2007
Rca 27v412t tv picture only in middle of sceen
It is the fault with some components related with its horizontal scan output section circuit. Just check the circuit part; and check the components I've marked in red here by its horizontal scan output circuit. Beware; you're going to touch the most dangerous part of its circuit. Keep it in mind always.
24780559-dmive0z32bcpzrsafcaw1enm-4-0.jpg If you wish to see the circuit diagram in full; visit
http://schematicscom.blogspot.com/
Jul 07, 2014 | Toshiba 36A50 36" TV
Picture is too large to show on screen
Check its "Pin-cushion" section circuit for the fault. An IC is used there to control the pin cushion distortion. If this IC has got faulty, this type of fault can occur. This is actually a skilled work. If you are not ahndy, seek any technicians' support.
Jun 18, 2012 | Sony KV-36XBR400 36" TV
36' toshiba with red screen and glowing horizontal lines.
Bad connections on red drive transistor on crt module. Resolder all connections on crt pcb.
Nov 25, 2011 | Televison & Video
On Sony 36 iinch Trinitron TV, when I go to HDTV channels the picture size changes to widescreen. How do I adjust back to full screen on HD? I tried the "no zoom" button but that doesn't work. Cannot...
Please note that all HDTV channels project wide screen pictures. You can still go to settings and then picture mode and change the format to 4:3/full mode.
Aug 28, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
I have a Sony Trinitro 36" about 8 yeras old. When I first turn it on, I can hear the sound but the picture goes in and out a few times before it stays on, now it is doing it every once in a while during...
Its a good bet that the picture tube is going bad. Thats the classic symptom of a failing tube. The tubes if available cost more than new tv's.. Sorry
Aug 11, 2010 | Sony Televison & Video
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony Trinitron (analog) picture suddenly ''pulsating''
the verticle has a problem check the following around that area
capacitors
zener diodes
resistors changing values
what is happening is that a voltage is not constant, its varing
Mar 05, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Multi color stripes on 60 inch sony wega, no picture
it sounds like the projection unit went out. if it is still under waranty then i would take back and get it fixed for free. if anything i would contact sony and tell them what is wrong with the tv.
Dec 19, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Philips TV Model 32DW6557/05 Screen Problem
hi it sounds like a capacitor in the verticle circuit located on the main board. it is near the verticle ic. the verticle ic also could be bad the cost is around 85 dollars for a tv shop to fix. sometime a cold joint could be found around vert ic. a soldering iron is required with solder.tap the side of tv if picture comes back it is just cold solder joint.
thanks Doctor video
Apr 25, 2008 | Televison & Video
Picture too big
The horizontal size adjustment is in the service menu only. I would suggest someone who knows the code to do it for you.
Jan 25, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
109 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
