Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Hp pavilion not turning on
Hi, i am really desperate, i left my laptop at home switched off for 3 weeks and when i tried to switch it on again it was not responsive although it looked like the power supply is ok. what should i do? thanks oanamoscovici@yahoo.com i left my laptop at home switched off for 10 hours and when i tried to switch it on again it was not responsive although it looked like the power supply is ok. what should i do?thanks
  • sexy_spice01 Jan 31, 2009
    i actually tried that this morning but i did not work
  • 38 Answers
Try unplugging and removing the battery, letting it sit for a few minutes, then plugging in the adapter (battery still out) and try turning on again.
Posted on Jan 31, 2009
  • graindart Jan 31, 2009
    I know this probably sounds silly, but did you verify the outlet is working properly with something else. I only ask because I once was having problems with charging something and then found out that a GFIC breaker had tripped in that circuit and the outlet didn't have any juice.
2 Suggested Answers
Ravege
  • 327 Answers
SOURCE: hp pavilion not turning on
try to remove the battery and plug the system in with no battery and try to turn it on if this does not work put the battery back in and ...to turn on hold the on button in for 5sec and should turn on if not could be a problem with a power surge when you was gone and the M/B got messed up
if the power supply is ok that is make sure when pluged in the light comes on so you know you have power
Posted on Nov 02, 2008
Laptop power LED switches on but switches off again
Yes, but it involves board level component replacement....
An example of what I believe the problem may be, and using the HP Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's;
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
http://www.mouser.com/Search/Refine.aspx?Keyword=FDS6679
http://www.youtube.com/watch?v=3NN7UGWYmBY
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=135&prodSeriesId=3958407#2
Compaq 615 Notebook PC and Compaq 610 Notebook PC - Maintenance and Service Guide
Wear an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Or replace motherboard at a $100 on up.
(NOT including labor. Just price of motherboard)
Or it may be something as simple as the laptop is dirty inside, plus the Thermal Paste on the Processor has dried up; and Thermal Pad on graphics chipset has dried up. (Cannot be reused anyway)
For additional questions please post in a Comment
Regards,
joecoolvette
Apr 30, 2013 | Computers & Internet
Where is the WIFI switch on Hp Pavilion dv9000?
Looking at your laptop from the front, on the front edge (from your left going to your right) you will see:
1) Power light
2) Battery light
3) Drive light
4) Wireless (Wi-Fi) switch
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 03, 2010 | HP Pavilion dv9000z Notebook
Screen dim HP pavilion dv1000
The lid actuator switch may not be working correctly. It's a small switch above the keyboard and led's on either the right or left side. Try pressing it 2 or 3 times to see if the display starts working correctly again. If so, it will need to be replaced.
If that doesn't work, you can also turn it on with the ac adapter plugged in. After it boots, press the power button and hold it in until it shuts off and then turn it on again and see if the display has returned to normal.
If neither of these options work, your laptop may need to have the backlight replaced.
Aug 13, 2009 | HP Pavilion dv1000 Notebook
The on button wont switch on my laptop
Please try following DIY
1.Remove the battery and press the power button for one minute.
2.again plug in the battery and try to start.
3.open the RAM chamber and refix the RAMs.
Jul 14, 2009 | HP Pavilion dv6000t Notebook
My HP Pavilion Entertainment PC will not turn on!
CHECK IF U ARE RUNNING ONLY ON BATTERY SO TRY TO REMOVE THE BATTERY AND INSTALL IT AGAIN AND CONNECT THE CHARGER
Jun 07, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Laptop will not turn on
The only suggestion I can think of trying is to remove the battery and mains lead from the unit wait 5 mins then plug the mains in without the battery present. If the unit does not start after this then it's likely an issue with either the plug pack or the notebook motherboard. Try wobbling the connector going to the laptop and see if its a loose connector. Get the plug pack tested with a voltmeter to see that it's working.
Has the new plug pack got a removable end piece or is it hard soldered, if it's got a removable end piece has anyone accidently reversed this causing + to go to - or vice versa?
If the above tests don't prove positive then I'd say the unit will have to go in for service.
Hope this helps
May 25, 2009 | HP Pavilion dv4000 Notebook
Wireless switch will not turn on
Common problem with motherboard.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&product=1842189&lang=en&docname=c01300427#c01300427_dv62
Jan 21, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Nov 01, 2008 | HP Pavilion dv1000 Notebook
Hp dv 2000 power switch wires 3
To know exact locations of the notebook inner parts, you can try the below manuals of DV2000. Hope this will resolve the issue.
http://h10032.www1.hp.com/ctg/Manual/c00729555.pdf
It is Service Manuals of your notebook model.
Sep 07, 2008 | HP Pavilion dv2000t Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
