Question about GE 46GW947 46" Rear Projection Television
Red, blue, and green lamps
We got a free tv from a friend that said it was broken. After replacing a fuse it works fine. But it traveled on its back and messed up the 3 lights inside. The red, blue, and green lights inside do not line up now. How can I fix that?
  • 87 Answers
Get into the customer menu and go to #3screen. In that menue you should see #4 convergence. If this is not there you have a problem in the convergenc power supply,
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Aug 02, 2007
My zenith tv model SR2075DT had this continous Red tint. I have tried fixing it through settings and NOTHING works. Someone please help me
It is likey the blue lamp has failed.
They are relatively cheap to replace and you can buy them online.
There are dangerous voltages inside the cabinet.
If you can see the lamps through any of the vents, you may be able to see the lamps. Check to see if blue or green are not working. There should be three separate lamps. Red Blue & Green. This is assuming the colour is like that on all sources.
If it is only on one source, check the component cables in the back of the TV.
Oct 20, 2013 | Televison & Video
What causes the picture to have a green tint
there are 3 color cathode in your TV red,green,blue cathode.The red and blue cathode might not working in your set that is why you have a green screen. Open the back cover of your TV you can immediately see the 3 cathode lamp at the back. Clean the lamp first using a clean clothe. Power up you tv and see whether the 3 lamps are lit. If lamps do not light up,check the circuit board where this lamp is connected re-solder all the components in this lamp. There is also an individual screen adjustment for the lamps it is located at the front panel and labeled RGB screen...try this first and let me know how it goes..
Apr 16, 2011 | Zenith E44W46LCD 44" Rear Projection...
KDS-R60XBR1 no sound no picture continuous green flashing a pause 6 green flashes then continuous red flashes from the lamp indicator. Is it the lamp or something else?
It is lamp that is dead/ broken, replace lamp to get back tv in working.
Lamp replacement procedure is written in user manual and its easy.
Thanks.
May 11, 2010 | Televison & Video
Our Sony Grand Wega suddenly has a green-yellow tint.
IF IT IS HOOKED UP WITH COMPONENT CABLES (GREEN, RED, AND BLUE) FOR PICTURE AND RED AND WHITE FOR AUDIO, MOST LIKELY THE RED ONE IS NOT SEATED PROPERLY, CHECK BOTH ENDS THE ONE CONNECTED TO THE TV AND THE ONE CONNECTED TO WHATEVER THE SOURCE IS ( SATELLITE BOX, CABLE BOX ETC.
Oct 06, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
3D TV Blues, Greens, Red and a little yellow. RCA Modle # R52WH74
This is called convergence board failure. try to re calibrate the convergence. if the re calibration fails, this means your convergence board will need to be replaced or, rebuilt.
Feb 13, 2009 | RCA R52WH73 Projection Television
1989 Mercury Tracer Sta. Wgn.
your owner manaul has it. your fuse cover should have chart too.
here is 96 tracer. You also have main fuses under hood.
INTERIOR FUSE JUNCTION PANEL REFERENCE CHART Fuse Fuse Rating Color Protected Components (REAR WIPER) 10A Red Rear wiper and washer motors, heater and A/C relays, daytime running lamps control (Canada), climate control assembly panel illumination HAZARD 15A Blue Front and rear turn signal lamps, turn signal indicator lamp, indicator flasher ROOM 10A (1.9L)
15A (1.8L) Red
Blue Dome and map lamps, safety belt warning chime, ignition key illumination, luggage compartment lamp, vanity mirror lamp, radio chassis (memory), power door lock relay, shift interlock system, powertrain control module (PCM), radio amplifier (memory) ENGINE 15A Blue Fan control (FC) relays, PCM relay RADIO 15A Blue Radio chassis, radio amplifier, remote control mirror, instrument panel illumination (DOOR LOCK) 30A Light Green Power door lock actuators BELT 30A Light Green Passive restraint control module, passive restraint motors (POWER WINDOW) 30A Light Green Window regulator electric drives METER 15A Blue Instrument cluster, backup lamps, rear lamps, speed control system, shift interlock system, safety belt warning chime, passive restraint control module, hazard flasher, PCM (1.8L Canada) WIPER 20A Yellow Windshield wiper motor and windshield washer pump STOP 20A Yellow Stoplamp, horn (1.9L only), rear hi-mount lamp TAIL 15A Blue Parking lamps, cornering lamps, rear lamps, license lamps, compartment lamp, instrument panel illumination (SUN ROOF) 15A Blue Sliding roof panel motor ABS 10A Red Anti-lock brake system (ABS) (1.8L only) (DEFOG) 20A Yellow Rear window defroster HEATER 30A
circuit breaker — A/C blower motor HO2S
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 10A (1.9L)
20A (1.8L) Red
Yellow Heated oxygen sensor (HO2S) CIGAR
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 20A Yellow Cigar lighter knob and element CIGAR 20A Yellow Cigar lighter OBD II 10A Red Data link connector #2 BLOWER 30A Light Green Blower motor relay HORN 20A Yellow Horn (1.8L only)
Aug 10, 2008 | 1989 Mercury Tracer
Projection TV - Red Lamp not on
You can get a replacement Red CRT at the following link its used in good working order for 135.00 with free shipping compared to about 375.00 for new if available. The site also provides free step by step instructions on how to do the installation.
here is the link http://servicemanuals.vstore.ca/
Apr 04, 2008 | Televison & Video
Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Oct 15, 2007 | Sony KP-57WS500 57" Rear Projection...
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
GE 46GW947 46" Rear Projection Television Logo
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
