Question about Rancilio Rocky Espresso Coffee Grinder - Doser
I just got a used Rocky grinder. It works great but I read about
How quiet it is. Mine is not. Does it have any lube points?? or suggestions? George
    Novelist:
  • 137 Answers
The grinding itself makes noise. if you have noise in empty spinning than you should consider changing bearings( 2 of them) in the motor.
during opening grinder pay attention to lower holder of burr which spins together with axis, try to be gentle with that part.
Posted on Apr 04, 2009
My Rancilio Rocky Burr coffee grinder w/doser is not grinding the beans they simply remain in the hopper
It is most likely that something is blocking the pathway to the grinder. As the Rocky is a direct drive grinder there is no gear that could be broken.
Try to remove the beans from the hopper and inspect the pathway, move the beans that might be under the 'disk'. If that is not working you might have to open the grinder;
  • remove all coffee beans
  • unscrew the three screws in the bottom of the hopper
  • remove the hopper
Now you can see the grinder wheel and tell if it is turning normally.
This might be a good opportunity to give the grinder a thorough cleaning.
Do not soak it in water, just a stiff small brush (e.g. a toothbrush) is the best tool. And perhaps accompanied by a vacuum cleaner :)
If you have been using very 'oily' beans for a long time they might have clogged the grinding wheels.
Good luck,
Villi
Mar 02, 2015 | Rancilio Coffee Makers & Espresso Machines
Ref: Mr. Coffee Burr Mill Hopper: How do I keep the housing of the grinder from filling with large amounts of ground coffee?
You need to clean it out every 3-4 days. I use a brush and pointed knife for the packed grounds. Mine works great now.
Nov 27, 2014 | Mr. Coffee Coffee Makers & Espresso...
Have Rancilio Rocky for about 3 months. Noticed grinds around base from time to time. Yesterday picked up machine, saw accumulation. Tapped base, more came out. Took off base, about 2 oz. of grinds inside....
Hi There could be a piece broken around the chute where it comes out of the grinder and enters the grounds chamber. There is a rectangular opening in the plastic that can get broken causing the grounds to enter the machine.
Feb 07, 2010 | Rancilio Rocky Doser Espresso Grinder...
I have a Rocky Grinder. The spring that pulls the
no, dont worry. Just return the lever by hand. Replace the spring and it will break again. It is a hassle to replace and not having it will not affect the function
Sep 19, 2009 | Rancilio Rocky Espresso Coffee Grinder -...
Rancilio rocky grinder setting
to get starting point you adjust burrs to touch each other. when they touch each other you have finest grinding, after you hear metal voice you turn back 3 dots and grind only for 1 dose. you check it, if it goes to slow, you go one more back and clean gruinder, THAN you grind 1 dose more. 2 or 3 times and you will get perfect grinding.
Mar 28, 2009 | Rancilio Rocky Espresso Coffee Grinder -...
Replacement portafilter holding fork
i will give you one web adress, i hope it is near you.
http://imp.mallcom.gr/coffee/coffee-rancilio.pdf
www.nuovaricambi.it
Jan 02, 2009 | Rancilio Rocky Espresso Coffee Grinder -...
Adjusting grind on Rancilio Rocky
  1. because it didn't work a wilde the upper burr holder could be jammed, carefully take id off, clean it good and then put it back until you touch lower burr with the upper.
  2. to get starting point you adjust burrs to touch each other. when they touch each other you have finest grinding, after you hear metal voice you turn back 3 dots and grind only for 1 dose. you check it, if it goes to slow, you go one more back and clean grinder, THAN you grind 1 dose more. 2 or 3 times and you will get perfect grinding.
Dec 09, 2008 | Rancilio Rocky Espresso Coffee Grinder -...
Rocky Calibration
  1. replacement of burrs after 500 kg grinded coffe
  2. if upper burr holder and the body of grinder does not hold stabile, teflon aplying does not help too much, it is only temporary solution. new upper bur holder would do better.
  3. before inserting upper burr holder you should check if lower burr is rotating syncronized, you should take a bit chalk and sof touch while burr rotates. after that you stop grinder and look do you have circle with same thiknes, that would give you idea where is the problem, if it is in lower burr.
Apr 07, 2008 | Rancilio (RAROCKYND) Grinder
Coffee Makers & Espresso Machines Logo
316 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
