I need a manual for my RCA CD player. # is RP2700A Where is the Pause button?
    Problem Solver:
  • 7 Answers
The pause button is the play button, just push the play button during a song and it will pause the unit til you are ready to resume
Posted on Sep 15, 2009
  • 360 Answers
The pause button is the same as the play button....
Here is a link for your owners manual -->click here<--
Please take the time to rate this solution Fix Ya
Thanks for using FixYa
Posted on Jan 31, 2009
My rca m4304-A mp3 player says profiling requires 20mb free space shutting down and then when i try to hook it up to the computer it will not show that it is hooked to the computer and goes off
Restoring RCA M4304A Recorder Firmware
Symtom: recorder shows OPAL splash screen, then shows "profiling requires20mb of free space, shutting down" and then shuts down. Recorder cannot be accessed by windows or the RCA easyrip software.
Solution: Use the firmware update found here: http://www.voxxsupport.com/images/downloads/OPAL_066F_85A4_85A5_0_1140_SIG.EXE
This update needs to be ran on an xp computer running 32 bitOS. It was tested in a Win 7 64bitmachine and proven to not work.
Necessary steps taken to get the firmware to properlyrestore were as follows:
1. Hold in the power (menu) button for 10 seconds(the splash screen will show and it will give the error message, ignore it)
2. While still holding the power button, press theplay/pause button and hold down.
3. Release the power button while still holdingdown the play/pause button and wait 5 seconds.
4. While still holding the play/pause button plugin the usb cable to the recorder. Continue to hold the play/pause button foranother 5 seconds after plugging the cable in.
5. Release the play pause button then launch theEXE for the firmware update. Minimize the instruction screen so you can see thefull update screen.
6. Leave the format checkbox checked (check it ifit isn't checked) formatting is crucial to this working.
7. Once the status in the update window changesfrom initializing to ready click start to update the recorder. It will go through formatting, then updating.
8. Once the status shows complete disconnect therecorder and with any luck the recorder is usable again. The media files will obviously have to bereloaded, but the recording is functional at least.
Sep 21, 2010 | RCA M4204 MP3 Player
Pause/resume function in analogue, manual recording mode
This player has essentially the same guts as my Pioneer PDR-509, so this is what it means...
'Repair' means the player lost power in mid-recording without commiting the track memory to a table of contents. It would likely take up to 40 minutes for the player to reconstruct it from the disk.
There is NO reason the player need be turned off (if that's where it took you) for a track pause.
Just press Pause, flip the LP over and hit Play or Pause again when you wish to continue recording.
Perhaps you don't know how to Finalize the disc either. It's not that intuitive. Press Finalize, after a while it will display a time, like 4:07. That means how long it will take to do the operation. Now press Pause and it will count down to 0:00 and be done. Then you can play it on any other CD player.
Feb 14, 2010 | HHB 830 Plus CD Recorder CD Player
CD's won't play in other machines
Your problem is an easy one.....you need to "finalize" your completed/burned CD first...then it'll play in tray A...and others. Good luck....from Middleman
Feb 07, 2009 | RCA CDRW120 2-Disc CD Recorder
Cannot set the time, need manual for our RCA RS2620 system
hold in the "clock" button until the hour flashes
use the forward & back buttons for the cd player to set the hour. (located just to the right of the equalizer" button)
once the hour is set, press the "clock" button until minutes are flashing.
use the forward & back buttons for the cd player to set the minute.
once done, press the "prog.set" button below the forward & back buttons
Dec 31, 2008 | RCA RS2620 CD Shelf System
How to cut the rca opal-mp4002 on?
Once it has charged for the 3 hours, unplug the player from your computer and hold in the Play/pause button for 5 to 7 seconds, until the player turns on.
-Tha Mp3 Doctor
Dec 27, 2008 | RCA OPAL M4001 MP3 Player
RECORD
Hey EMURK72,
According to information provided by the manufacturer, you should be able to enable voice recording by following the steps below:
1) Press the menu button ("M") twice to enter the main menu.
2) Press the "+" or "-" button to highlight "Voice Recording," then press the next track button to advance.
3) Press the "+" or "-" button to highlight "Record," then press the next track button to enter voice recording mode.
4) If you press the "●" button when the display screen says "Ready," you should then be able to start voice recording.
5) You can press the "Play/Pause" button to pause and resume recording.
6) Pressing the "●" button a second time stops recording.
If you'd like more information or step-by-step instructions that include visual aides, you may wish to refer to your owner's manual.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 03, 2008 | RCA TH1101 MP3 Player
M4204 dead
Run the installation CD first, before connecting.
Are you running vista? You may need a clean version of the installation software from RCA's website.
May 28, 2008 | RCA OPAL M4001 MP3 Player
Stopping partway through a CD.
This is not possible to change as it is the nature of all CD players, unlike DVD players which give you the stop/resume function. Cd players have a similar function called pause, but other than that its alm,ost impossible to fully stop and start off again from where you left off unless you skip to the track and hold the skip button to fast foward/rewind.
Dec 26, 2007 | RCA RP2710 Personal CD Player
RCA MP3 M202E
ok... when your looking at it from the front (screen forward) on the right there are 4 buttons.. the top button is play/pause push that the turn on the mp3 player. underneath the play/pause button is the stop button this stops the song and when you hold the stop button down it turns off the mp3 player. the next buttons are the skip forward and skip backward buttons.. on the left side, the very top button the longer shaped one is the +/- volume button. underneath the +/- button is the equalizer button push this to changed the sound of the device.. and the last button i have yet to figure out.. i hope this helps you..
Jun 19, 2007 | RCA Lyra M2030 MP3 Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
