Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi VS-70605 Turns itself off
When you turn it on, LED flashes once and then it shuts off. Also gives a code 22. Had a tech out today, not sure what he did, but now the LED flashes once and then 3 quick flashes. Also gives a code 12, which I understand to mean no code. Tech didn't say he did anything. Only that he couldn't fix it at my home. There appears to be a new fuse installed in it? He didn't mention it. He said it could be a horizontal output transistor that hot-shorted. Possibly causing a horizontal drive circuit problem. And it may need the flyback replaced. Does this sound right? He also said it could be about $300 (not including the $65 house call fee). Any help would be greatly appreciated!
    Genius:
  • 1,153 Answers
Need to know what the code is now if 22 then it's the low voltage protect and could be convergence amps.
Posted on Sep 20, 2007
SOURCE:
Mitsubishi
YOU NEED TO CALL THE MITSUBISHI TECH SUPPORT, THEY SHOULD BE ABLE TO TELL YOU FOR FREE THE POSSIBLE TROUBLE...JUST EXPLAIN THE ERROR CODE..GOOD LUCK
Nov 10, 2013 | Mitsubishi VS-70707 70" Rear Projection...
I have mitsubishi vs 60719 chassis vz9 will not power up error code 21 all standby voltages are good 5 fuses are good when plugged in led 3 flashes led stays on for 15-20 sec no relay clicking or any...
most of the time the convergance ic go bad:
but try this:
The 3 flashes of the led when you plug the unit in is the
microprocessor initializing.
This unit has an error code diagnostics.
On the front panel of the unit press and hold the INPUT and MENU
buttons at the same time and hold them down for about 5 or 6 seconds.
The unit should activate it's error code mode.
The led will flash count the number of flashes. It will then pause for
1/2 or 1 second. The led will flash again count the number of flashes.
The unit will repeate this for about 5 or 6 times.
You now have the two digit error code. The first time the led flashed
is the first number of the error code, the next time the led flashed is
the last number of the error code.
12 ----------- indicates no error
21 ------------- X-Ray Protect circuit
22 ------------ Short Protect circuit
23 ------------- Horizontal Deflection failure
24 ------------- Vertical Deflection failure
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
If Q5A00 check bad there are other parts that have to be checked or
replaced.
If you are able to do above call a tech to service the unit
Sep 17, 2008 | Televison & Video
The tv is a model# WS48311 serial# 106199. The prob is the set turns on (green light) after 1-2 seconds it shuts off It is a Mitsubishi
Hi Sheldon,
First of all, thank you for posting your question here at Fixya.
The symptoms you've mentioned is an indication that the unit gone to malfunction. My first advice is to unplug the unit from the outlet(AC source) for at least 15 minutes to reset the system and then check if the symptoms remain the same. If yes, lets check the LED error code to determine where the fault came from by following the steps below.
Press and hold for 5 seconds the front panel button keys "Input" and "Menu" at the same time to activate the error code mode. The LED will flashes a two digit error code.
Example : if the error code is "22", the led will flash two times pause and then flash again two times and the error code will cycle for five times.
Please let me know the result to continue our diagnosis.
mjsazon
Jan 17, 2012 | Mitsubishi WS-55513 55" Rear Projection...
It was working fine until yesterday. It shut itself off. I powered it back on and befor the screen could come back on it shut itself off. I checked cables and uplugged it for 24 hours. The first time...
Hi Daniel,
Please check if you can access the "error code operational check" to narrow down where the fault came from.
How to enter to error code operational check.
Note : The TV must be in shutdown and not have been switched off. When the TV is switched off, the error code automatically resets to 12 (no error).
Press the buttons on the front panel "Input/Device" and "Menu" at the same time and hold it for 5 sec, activate the error code mode. The LED light will flashes denoting a two digit error code.
Example : if the error code is 22, the led will flash two times pause and then flash two times and will repeat the error code for five times.
If you can't access the error code operational check , please let me know the exact pattern of the flashes of the led light and its color. Check if it will continually flashes green to give you the caused of the symptoms and best solution.
Good luck and take care.
Nov 15, 2011 | Mitsubishi VS-50805 50" Rear Projection...
AFTER TURNING ON TV ,THE GREEN LIGHT COMES ,SOUND STARTS AND THEN TV TURNS OFF ASAP
after tv shuts off press and hold menu and input buttons on tv at same time for about 8 second. power led will start to blink error code 12 ok 22 dead short 23 deflection failore 24 vertical failore. after you know error code have electronic technition repair for you. J.D.W.
Jun 24, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Vs-50607 turns off by itself it might come on after about 8hrs
if you hold menu and input on the front panel it will blink a code to tell you
where the error likely is. hold the buttons for 5 seconds and you'll get a 2
digit error, like 1 2 = no error..
“12” ... indicates no error has occured.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.
let me know what you find.. it will determine area of failure
Jan 08, 2009 | Mitsubishi VS-50607 50" Rear Projection...
I turn on tv, then turns itself off.
By the way do you have the service manual with you?
Oct 21, 2008 | Mitsubishi VS-60111 60" Rear Projection...
Set turns off on its own
when it shuts down press menu and input buttons both in together on the front panel and hold in for 8 seconds and see if the LED blinks a two digit code . If so let me know the number of blinks
Jun 17, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50705, 50 inch Rear projection TV won't turn on!
but try this:
Q5A00
C557
replaced.
Dec 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
57 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
