Question about Denon AVR-2800 Receiver
AVR-2800 My unit shows that it has power but it won't turn on with the remote or power button.
Unplug for 24 hours then try again
Posted on Apr 22, 2008
4 Suggested Answers
SOURCE:
SOURCE: Denon AVR-2800
Hi, This is because your unit goes in to protection mode because of some bad connection in the input/output section .Disconnect your spkrs,inputs..turn the volume is Down all the way and power it up,Check your wiring for shorts at the inputs and outputs. at your service sreejith
Posted on Jul 31, 2007
SOURCE: My unit has power, but it won't turn on at all.
i had this same problem yesterday. what you have to do is 1) check all your fuses, 2) check your ground\ power 3) you might have to wire your power wire to your steering console (thats what i had to do)
Posted on Aug 10, 2007
I'm having the same problem.
Posted on Mar 11, 2008
Reset factory settings of my Denon avr 2800
From Denon support:
To reboot, turn receiver off using the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory default.
Sep 08, 2013 | Denon AVR-2800 Receiver
Denon AVR-2800
Jul 31, 2007 | Denon AVR-2800 Receiver
Reset factory settings on my devon avr 2800
From Denon support:
To reboot, turn the receiver off using the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory settings.
Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Aug 23, 2012 | Denon AVR-1908
I have a denon avr 2802. the remote powers the
Try doing a factory reset by turning off main power switch.hold down speaker a and b buttons while turning on main power switch ,display will flash 3 time s then release buttons,this then returns unit to factory default settings.
Apr 13, 2010 | Denon AVR-2802
I just got an avr 2800 but cant get any sound
it has a built in tuner, but it's difficult to use. The remote is the easiest way to tune manually. If you don't have the remote, I'd D/L the manual from dennon.
Aug 25, 2009 | Denon AVR-2800 Receiver
Dennon avr-2800 Remote problems??
Unplug unit for 24 hours or if there is a reset button on back panel -- press and hold for ten seconds
Apr 21, 2008 | Denon AVR-2800 Receiver
Denon AVR-2800
This means that something is seriously wrong with the unit(blown amp, shorts, opens, etc.) however, you can reset the unit by unplugging the unit, holding the A and B channel buttons on the face of the unit and plugging in the reciever. the display should flash at 1 second intervals. if it doesn't stop flashing on its own then unplug and replug and you should be good to go! good luck.
Denon AVR-2800 Receiver Logo
113 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
