Question about X-10 X10 Pro PLW01 Standard Toggle Single Wall switch
X10 switch paddle problems
Switches dont work with paddles . they work after hitting them many times an then work just fine some times. a smart home product #238851 .do you know of a wide spread problem.the people there said to take apart an put tape on contact. i dont think that would work
  • 547 Answers
Please change switch and stop hitting it most likley is a short or bad connection could start fire
Posted on Feb 12, 2009
Legrand adorne paddle 3 pole switch won't turn on
You need to have 2 two way switches in a circuit like that. If you dont have them in each place then it will not work. If you did have a two way in each spot then when you put the new switch in, there is a chance that you wired it wrong. How many wires are in that box that you put the switch in?
Apr 16, 2014 | Electrical Supplies
Samsung model rf4287hars only dispenses water when ice lever depressed
3b662ccb-018c-4390-ab7a-74a2025960df.jpg 3d562c7f-18a6-4fa7-9993-373c8c5d3c7f.jpg 763378c4-5f13-435a-aac3-b67d9041b031.jpg
First photo shows paddle assembly that can be purchased you need to got to Sears web site to find part # other wise you will have to buy the whole circuit board assembly hundreds more than the paddle assembly. The circuit board and paddle assembly is removed buy removing screw on inside of door and pulling it out be careful it seems strange but it just pops out. The paddle assembly slides on to the circuit board assembly look close and take your time to slide it off I thought I was going to break mine but did not and save me big money.
Second photo shows tab for water dispensing still there.
Third photo show ice dispensing tab broken and missing.
If you leave the assembly plugged in press the micro switch for the ice dispenser and see if it works most likely the tab has broken and is what hits the switch telling the door to open and ice dispensing screw to push ice to the door. Hope this helps
Mar 04, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
I have a 05 neon that wont shift out of second gear. When I first crank and drive runs fine when I break or stop check engine comes on. I can reset it then it will shift but after five minutes light comes...
It could be due to malfunction of brake paddle switch. you have to check brake paddle switch. if brake paddle switch get choked it can be happen due to Peddle switch gives signal to ECU as a vehicle stopped.
Apr 15, 2013 | Cars & Trucks
No brake lights when brake pedal is pushed
check first wirring is work properly, and check lamps are work properly. If not then change lamps.If works properly then check connectors, and paddle switches are work properly. If not then change the connector and paddle switches.
Aug 26, 2012 | 1995 Toyota Camry
Kenmore washer 80 series stopped draining
So it will agitate and fill but the motor won't run during drain and spin?
If so, the likely cause is a bad lid switch. The paddle that the probe hits when the lid is down moves a small switch. That switch can do two things
1. fail internally. It will look fine outside but it won't close the circuit
2. the screw holes snap and it hangs off the wires, the probe no longer hits the paddle and the switch stays open.
The lid switch is cheap and very easy to repair.
Nov 10, 2011 | Kenmore Washing Machines
My Toro 221E, model 38582 is 3 years old. It ran great this morning (blizzard, 14" snow). When I got home from work in the afternoon to continue, it started fine but when I engaged the paddle to...
Hi, will try to help. This sounds like there is ice or debris that is in around the paddle or the auger preventing to turn at full speed. Without the blower running, look all over around the paddle and auger and get out anything that might be in there. I think that is the problem. This has happened to me many times, and have repaired many like that. I hope this helps you out. All the best and good luck.
Feb 02, 2011 | Toro Garden
The washer will fill and agitate but it wont spin or wont drain
Hopefully you see this link before it gets removed
www.applianceaid.com/procedures.html
Jul 09, 2010 | Kenmore 22422 Top Load Washer
Error code
C11A0
Paper holding drive
failure
• The exit paddle home position sensor (PC6) is not turned ON
even after the set period of time has elapsed after the exit
paddle solenoid (SL2) is activated (beginning of paddle
retraction operation).
OFF even after the set period of time has elapsed after the
exit paddle solenoid (SL2) is activated (beginning of paddle
paper-holding operation).
This will probably need parts as the paddle assembly is likely to be broken.
Nov 20, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Whirlpool LER2614 repair
The problem was that the dryer did not work when the start button was pushed.
The cause was the paddle that controls the door switch. I fixed it but thanks to those who gave suggestions.
Mar 28, 2008 | Whirlpool LER2614JQ Electric Dryer
In door ice and water dispensing
sounds like the paddle is hanging up or the micro switch that the paddle actuates is sticking if you can see the micro switch spray some wd 40 on it open the door and work the paddle a few times
Feb 15, 2008 | Frigidaire FSC23F7D Side by Side...
X-10 X10 Pro PLW01 Standard Toggle Single Wall switch Logo
259 people viewed this question
Top X-10 Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a X-10 Electrical Supply Expert? Answer questions, earn points and help others
