Question about Canon PowerShot S1 IS Digital Camera
New chip needs a new chip
  • john brill Jan 31, 2009
    it needs a new sensor because the images are not visible due to purple stripes
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    new chip of what?
    let me know what exactly you have problem with Canon S1iS camera.
  • 10,594 Answers
OK,
you need CCD imager in this Canon camera to see live view to take picture.
Canon offers Free of Cost repair facility for bad CCD imager in S1 IS.
Click Canon CCD Advisory for details
Do not forget to rate this solution.
Posted on Jan 31, 2009
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Chip in key deprogrammed activated
This needs to go into a VW agent to get the key transponder programmed to the Immobiliser system.
Jan 17, 2014 | Volkswagen Cars & Trucks
PTG-74PVN RHEEM TANKLESS WATER HEATER NEED PROGRAM CHIP FOR NEW PCB THERE IS NO CHIP
The chip is missing off the PC board?
I thought the microchip was the main computing part of a board.
Are you talking about the microchip?
Call Rheem.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Sep 23, 2012 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Video chip remove
It is very difficult to remove a video chip that is soldered to the motherboard especially a surface mounted integrated device.
You most likely will damage the motherboard trying to remove the IC chip and if you did successfully remove the chip, you need special soldering equipment to install a new video chip if you managed to get hold of a new video chip.
Apr 20, 2012 | eMachines M6809 PC Notebook
2000 cadillac eldorado. need a new key can i replace it myself? if so how?
the chip needs to be read then a new key cut with that chip
Apr 15, 2012 | 2000 Cadillac Eldorado
Xerox Phaser 3500 - installed new toner still says it needs replaced. Is there a way to reset the message? We have powered off/on and it still says that it needs replaced.
the only way to reset the message is to replace the cartridge CHIP with new one or reset the chip with proper CHIP reseter(but i don't think that you have reseter).
This printer can write on cartridge chip and sometimes when you replace cartridges the printer writes directly the information from empty chip to new chip and that makes new chip EMPTY. This is some kind of bug. SORRY!!! CHIP is cheep so don't worry...be happy
pifonski
Mar 03, 2011 | Xerox Phaser 3500/DN Laser Printer
White dots on screen
Your DLP chip is failing. The tiny micro mirrors within this chip are stuck. More white dots will appear over time until it looks like a star field on your screen. Most places will tell you that you need a new light engine, however you can replace the DLP chip itself and it will take you about 30 mins. You can find the chip online for around $349 but I think I have DLP chip you need brand new for $225. If you are interested in this contact me. tharizen@yahoo.com
Feb 27, 2011 | Mitsubishi WD-Y577 Television
Thinkjet ink cartridges rejected by epson dx7400 - no matter how many times I try using my chip resetter, which normally works and lets the printer use the remaining ink in the cartridge.
The Epson 69 cartridges have two chips. One on the exterior of the cartridge and one just underneath. You can reset the outer chip before the cartridge is less than 25% full. If it drops below this amount of ink before being reset, the internal chip kills the outer chip. You will need to get a new cartridge or a new chip if this happens.
Dec 19, 2009 | Office Equipment & Supplies
CLP 300 toner cartridges don't have a chip
New Models of Samsung Laser printers come pre-packed with Cartridges that have no chips but an empty space where the chip should be. These chipless cartridges do not need to have a chip because the printer is pre-programmed to run for one cycle. These pre-packed cartridges can also be refilled in the same way but will need a reset chip.
Buy new chips from:
http://www.clp300.com/index.php?main_page=product_info&products_id=133
Sep 05, 2008 | Samsung CLP 300 Laser Printer
New ink cartridge for epson cx6600
If the computer shop said the new chips may not be recognized by the old printers then I would suggest you get an old cartridge which the printer recognizes and a chip resetter for Epson cartridges. Remove the new cartridge w/ the new chips and replace it with the older chip. You will probably need some double sided adhesive. When you pull out the chip you will notice 2 circular areas that hold the chip to the cartridge. One is actually like a small horseshoe so that you can slip it right back in. But the other one has a round flat end on protruding through the chip before you remove the chip. When you remove it, the plastic caves into the hole making it possible for you to remove the chip easily but impossible to put back. So to put in the older chip you need to snip out that piece of plastic so you have space to put in the adhesive. You can even use a small stretch of masking tape by rolling up about half an inch then putting it behind the chip. This way all you need to do it just change the chip everytime you run out of ink. It is a hassle but since you have bought large a supply of cartridges, don't waste it.
Apr 23, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Canon PowerShot S1 IS Digital Camera Logo
65 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
