Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE oven I own a GE gas oven / stove... the oven will come on to preheat but then it does not reach the desired temperature. I hear it cyle over and over.... the gas starts and then the elecric ignighter ignites the gas... the gas burns for just a few seconds and then the gas goes off... I think this may be a thermistat problem...
  • Anonymous Mar 24, 2014
    Is there a preheating light? How do you know when the oven reaches desired temp?
  • Anonymous Mar 28, 2014
    when oven gets up to temperature, it starts to ignite explosively. Why?
  • 5,911 Answers
Yup...I believe this may have been an issue with some GE models. I seem to remember a problem where some models had problems staying lit after preheating. The fix was replacing the oven thermostat. Now...the normal cycle for an oven lighting is just what you described. The glow igniter will glow first, followed by the gas valve opening, followed by ignition. Once the oven reaches optimum temperature it is normal for the gas to shut off and come back on to maintain oven temperature. However, if this is going on in a frequent fashion with the oven never getting warm, your guess is probably a correct one. Good luck to you.
Posted on Jul 31, 2007
SOURCE:
I need to learn how to use my oven, because i don't know how to turn it on.i need to bake,so can u tell me how?
You can get the manual for the RGB745 at the GE Appliances support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number in the search box. There are several models that start with RGB745.
On most of the Hotpoint ovens for regular baking, press Bake and use the + or - buttons to set the desired oven temperature. Then press Start/On. Then the oven will display Pre as it re-heats. When the thermostat indicates the desired temperature is reached, the oven will beep. The racks should be on the middle positions for most baking. (For roasting use the lowest positions.) Put the food in when the oven is done preheating. When done, press Clear/Off. Timed baked requires the clock be set correctly, then set the start and end times.
For the older ovens with dials to control the oven, set the first dial to Bake and the second to the desired temperature. Wait at least 10 minutes for the oven to preheat. Again put the oven racks in the middle of the oven for most baking.
Do not lock the oven latch and keep the oven closed through the baking cycle as much as possible. (Rotating pans and basting steps should be done quickly so that the oven doesn't cool much.)
I hope this helps.
Feb 11, 2011 | Hotpoint RGB745 Gas Kitchen Range
I noticed my oven was taking longer and longer to reach the preheat temperatures I was setting. As time went on, the stove was not heating up past 285 and now the temperature never increases but I can...
It is probably as simple as changing the ignitor...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 16, 2010 | Maytag MGR5770 Gas Kitchen Range
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven doesn't heat up properly
ovens can be calibrate for the right temperature. the adjustment screw is locate inside the shaft of the thermostat. when you remove the oven knob.
Nov 15, 2008 | Whirlpool GS460 Gas Kitchen Range
How do you tell if the oven is preheated to the correct temperature?
Follow this link to the online user manual, it describes the operation of this stove http://products.geappliances.com/ApplProducts/images/t07/0000009/r09077v-1.pdf
This should provide you with all the information you need to properly operate this model range,.. Hope this helps you.
Sep 01, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag advanced cooking system oven does not preheat to correct temperature and fails to reach the correct temperature
Once you put the desired temperature, select a cook time and it should solve the heating issue. Atleast that what worked on mine.
Jul 25, 2008 | Kitchen Ranges
Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Feb 03, 2008 | GE JBP24 QuickClean Electric Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
864 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
